sstein Posted March 31, 2008 Report Share Posted March 31, 2008 Hi, does anybody know where I can get a new lever blade for my magura HS33 with pre-05 master cylinder, the TPA adjuster on mine does not work and the lever does not push the main piston until it has moved about 1cm. Also has anyone else had a problem with slow returning pistons. I know it does not need rebleeding as I just bled it, I will re-hose it if any one thinks that it migh help. All advice is welcome. Quote Link to comment Share on other sites More sharing options...
Czar-rider Posted March 31, 2008 Report Share Posted March 31, 2008 Try tarty bikes and get a tpa kit,( i think select bikes are still doin CNC'd levers for £15 ) erm thats all i can think of or get a new lever blade and body alltogether?hope i helped m8cheers, jake Quote Link to comment Share on other sites More sharing options...
forteh Posted March 31, 2008 Report Share Posted March 31, 2008 I believe theres a wiki for fixing a broken tpa Sticky pistons are either dirt in the seals or lack of lubrication.Have you got an oil or water bleed? If its water then its likely you just need to lubricat the outsides of the pistons. Take the pads off and carefully pull the pistons out with some pliers, put a couple of drops of oil on the outside of the piston and this should free them up.If you have an oil bleed then the slaves are probably dirty, search the wiki for how to clean them out.With a water bleed you need to lubricate the pistons occasionally to extend the life of the seals and to stop the pistons sticking. Quote Link to comment Share on other sites More sharing options...
mista-neos Posted March 31, 2008 Report Share Posted March 31, 2008 Hi, does anybody know where I can get a new lever blade for my magura HS33 with pre-05 master cylinder, the TPA adjuster on mine does not work and the lever does not push the main piston until it has moved about 1cm. Also has anyone else had a problem with slow returning pistons. I know it does not need rebleeding as I just bled it, I will re-hose it if any one thinks that it migh help. All advice is welcome.I have a problem with my brake lever balde to. I snaped the pin that gets ajusted when you turn the TPA if you go to tarty bikes the lever costs £14.99 so yeh.x0x0-neos Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted March 31, 2008 Report Share Posted March 31, 2008 I had a problem with slow returning pistons just after i re-bled it. So all i did is re-bled it again and it was fine (tuch wood) so far. Scott. Quote Link to comment Share on other sites More sharing options...
sstein Posted April 1, 2008 Author Report Share Posted April 1, 2008 I have looked on tarty bikes for a new lever or tpa adjuster but they only do post 05 levers, etc.. does anyone know where I can get stuff for a pre 05 master cylinder Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted April 1, 2008 Report Share Posted April 1, 2008 (edited) There's a bodge that you can doWhere ou take the red knob off the lever blade,and put a bolt into it,i'll get the Wiki page for you....Edit:http://www.trials-forum.co.uk/wiki/How_to_fix_a_broken_TPABen Edited April 1, 2008 by Benjaminge Quote Link to comment Share on other sites More sharing options...
sstein Posted April 2, 2008 Author Report Share Posted April 2, 2008 I tried that except the nut that the TPA bolt screws into that is housed inside the lever is ruined and I can not find a new one. I tried to bodge it with a normal nut and bolt but I can't get the nut to stay in place. Quote Link to comment Share on other sites More sharing options...
