matt middler Posted March 30, 2008 Report Share Posted March 30, 2008 I just saw these on ebay. Has anyone used a pair or know anything about them.Are they any lighter or better than the standard blades?http://cgi.ebay.co.uk/Dangerboy-Replacemen...1QQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted March 30, 2008 Report Share Posted March 30, 2008 There made for 2 finger use apposed to 1 for a start Quote Link to comment Share on other sites More sharing options...
liam-pantera Posted March 30, 2008 Report Share Posted March 30, 2008 there also not magura hs33 levers , there dangerboy leveres designed for other magura disk's check the website . Quote Link to comment Share on other sites More sharing options...
The Duck Posted March 30, 2008 Report Share Posted March 30, 2008 There made for 2 finger use apposed to 1 for a start Well yeah, but if you want to use one finger, then all you have to do is put it in the outer little slot rather than the inner one. Bit complicated i know, but I'm sure if you have a good think about it for an hour or so - you'll figure it out. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted March 30, 2008 Report Share Posted March 30, 2008 you dont have to use two fingers... they look good but do they fit hs33 or discs? Quote Link to comment Share on other sites More sharing options...
JoeM Posted March 30, 2008 Report Share Posted March 30, 2008 They don't have holes for tpa's. Also, they wouldn't fit into the magura body as theres no hole for a bolt to go through. Quote Link to comment Share on other sites More sharing options...
