lehman GU Posted March 27, 2008 Report Share Posted March 27, 2008 as says above what is the perfect rear magura set up? Quote Link to comment Share on other sites More sharing options...
Muel Posted March 27, 2008 Report Share Posted March 27, 2008 One where the only standard parts are the lever body and the slave.In fact, one where there are no magura parts at all!RB lever.Deng slaves.Hope Hosing.Echo 4 bolt booster.Neco Yellows in heatsink backings.Echo Mounts.Inur's special radiator fluid bleed. (freezes at a very low temperature, makes the lever as light as water).Here is the spec of what my brothers brake will be once I finish it.Magura Lever, stop filed down, and the lump for the lever blade bolt filed off and replaced with a nut.Standard Magura Slaves.Supercycles Braided Hosing. £16 posted for the full brakes worth!Neco Yellows in plastic backings.Tensile Offset mounts.RB 4 bolt booster.Metal TPA.Water bleed.I am also toying with the idea of fitting a softer spring into the lever, to make it have an even lighter feel. Quote Link to comment Share on other sites More sharing options...
Gudron Posted March 27, 2008 Report Share Posted March 27, 2008 Inur's special radiator fluid bleed. (freezes at a very low temperature, makes the lever as light as water).Or LHM (LHM+) braking fluid for Citroen & Rolls Royse brakes. Like Maguras oil but cheaply (3$ for 1 litre) Quote Link to comment Share on other sites More sharing options...
Al_Fel Posted March 27, 2008 Report Share Posted March 27, 2008 My perfect set up is An 06+ Magura with a water bleed, brown koxx bloxx and a harsh grind. Quote Link to comment Share on other sites More sharing options...
Gudron Posted March 27, 2008 Report Share Posted March 27, 2008 Magura model 2004 + Koxx Brown + 4bolt booster + grind Quote Link to comment Share on other sites More sharing options...
forteh Posted March 27, 2008 Report Share Posted March 27, 2008 Maggie slaves (quicksilvers from about 1996 I think )RB leverEcho control 4bolt boosterHeatsink cnc redsDead grind (will regrind at some point)Water bleedVery light action, good hold and bite and pretty quiet (running a huge booster on a stiff frame sorts that) - its currently the best rear brake Ive had Quote Link to comment Share on other sites More sharing options...
FrancisJ Posted March 27, 2008 Report Share Posted March 27, 2008 Water Bleed (or standard)Echo LeverTar or Spray AdheisiveEcho PadsLight GrindFJ Quote Link to comment Share on other sites More sharing options...
Dan Burgess Posted March 27, 2008 Report Share Posted March 27, 2008 Water Bleed (or standard)Echo LeverTar or Spray AdheisiveEcho PadsLight GrindFJYer thats how my mate has them setup Quote Link to comment Share on other sites More sharing options...
Greetings Posted March 27, 2008 Report Share Posted March 27, 2008 +05 MaggieCNC mountsCNC Echo Lever (08 model)CoustsinksBraided hosingWater/radiator fluid bleed (feels the same)Feels like a Dengura but doesn't leak Quote Link to comment Share on other sites More sharing options...
Gudron Posted March 27, 2008 Report Share Posted March 27, 2008 Inur dupa - i know that word Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted March 27, 2008 Report Share Posted March 27, 2008 (edited) 2004 Maggie LeverMaggie SlavesPlaz PadsDead GrindWater BleedBIT Of Coke On The Rim!IMMENSE BRAKE!BenWater Bleed (or standard)Spray AdheisiveDoes that really work? Edited March 27, 2008 by Benjaminge Quote Link to comment Share on other sites More sharing options...
Ladd Posted March 27, 2008 Report Share Posted March 27, 2008 Magura 05Echo Lever 07GU mountsMetal TpaWater bleedBraided crossover Rock PadsMedium GrindPlastic Main Hose Quote Link to comment Share on other sites More sharing options...
Sam-Addy A3 Posted March 31, 2008 Report Share Posted March 31, 2008 Right i know this isn't really much to do with the subject but does a submerge blees just get the air out the brakes and keep the fluid in the brakes or does it get the air out and water bleed it?Sorry, bit of a stupid question but any help would be much appreciated Quote Link to comment Share on other sites More sharing options...
