Weld Or Not To Weld?
Andrew C
If my frame snapped i would firstly check any warranty's, i'm not going to buy a new frame if i can get a free one, then if there was no warranty i'd have my dad weld it up and if it ever snapped again i'd guilt him into thinking his weld led to me falling off and snapping the frame again so then i get a free frame complementary from my dad, either way i aint payin' !
Its a 2001 t-mag I just have it untill I get a gu le :$
Finally on the forum i see. And you never told me you were planning a GU LE <_<
The frame isn't snapped yet, just a few cracks, but they should hold until you get the LE. ( if you want it welded, my uncle could maybe do it for you ) .
If there just cracks you can drill a small hole at either end of the crack and that will slow it down. But don't do what mcinnes did and drill a hole big enough to acctully make the crack worse :P:P :P
