Alex.loves.boys Posted March 22, 2008 Report Share Posted March 22, 2008 Hi, my bb7s being shitits a 203 rotor with a deore lever.it used to work brillant but its died, it has the bite but when i gap to front it makes a sqeual and just doesnt hold anyone know why?should i boil the pads and rotor?? Quote Link to comment Share on other sites More sharing options...
Ladd Posted March 22, 2008 Report Share Posted March 22, 2008 Contaminated disc and pads? New disc and pads would be amazing, Just get the disc hot and pour water on it Quote Link to comment Share on other sites More sharing options...
Simpson Posted March 22, 2008 Report Share Posted March 22, 2008 Just worn out pads? I dunno just bash em out and have a look, just grip the tensioner clip and pull em out Quote Link to comment Share on other sites More sharing options...
dan_addison Posted March 23, 2008 Report Share Posted March 23, 2008 Clean the rotor with disc break cleaner. Check/clean pads, if the pads are contaminated sand them down a couple of mm. works everytime Quote Link to comment Share on other sites More sharing options...
basher Posted March 23, 2008 Report Share Posted March 23, 2008 New pads and rotar and new cable will sort it out. Quote Link to comment Share on other sites More sharing options...
craigjames Posted March 23, 2008 Report Share Posted March 23, 2008 Clean the rotor with disc break cleaner. Check/clean pads, if the pads are contaminated sand them down a couple of mm. works everytimeno it doesnt, if the pads are contaminated fully then what evers contaminated them most of the time has soaked through the pad material....New pads and rotar and new cable will sort it out.defo new pads, clean the disc with an alcohol wipe and then a clean cloth and water. new cable if the old one feels rough. should be sorted. make sure everything is set up square and is tight. Quote Link to comment Share on other sites More sharing options...
