dan more Posted March 22, 2008 Report Share Posted March 22, 2008 basically what it say in the title it wont move me and my dad have heated it up with a blow torch and it wont move how could i solve this problem ?thanks dan Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted March 22, 2008 Report Share Posted March 22, 2008 .. .. You are turnung it the right way ? Right ? Quote Link to comment Share on other sites More sharing options...
eskimo Posted March 22, 2008 Report Share Posted March 22, 2008 Have you tried undoing it with an extension bar while having the bb tool fixed on with the bb nut? Quote Link to comment Share on other sites More sharing options...
N.Wood Posted March 22, 2008 Report Share Posted March 22, 2008 Soaking it in penetrating lube usually helps a bit.Tightening it up slightly can break the seal if it'll go that way easier. Quote Link to comment Share on other sites More sharing options...
JonMack Posted March 22, 2008 Report Share Posted March 22, 2008 Are you turning it the right way? Non drive side comes out normally, drive side is a left hand thread so you need to unscrew it the other way. Quote Link to comment Share on other sites More sharing options...
cai Posted March 22, 2008 Report Share Posted March 22, 2008 Sometimes the threads (on the bb, and in the shell itself) can bend slightly, so it feels like its never going to undo - when realy its just about to! Try adding a 5 foot scafolding pole over the end of your spanner, that should help Quote Link to comment Share on other sites More sharing options...
dan more Posted March 22, 2008 Author Report Share Posted March 22, 2008 (edited) i have done all the normal thingd your ment to do when takeing it out the bb has seased up in the frame so its un rideable and stuck. i have turnt it the right way and i used an extension bar about 5 inches over my knee hight and used an ad one (metal pole) and the mofo still wont come off any more ideas to get it off would be apreciated thatnks dan Edited March 22, 2008 by dan more Quote Link to comment Share on other sites More sharing options...
Muel Posted March 22, 2008 Report Share Posted March 22, 2008 Bolt the tool in with the crank bolt and a spacer/washer, then bit a big ass adjustable spanner on it and gurn until it comes undone.Make sure your turning it the right way... Quote Link to comment Share on other sites More sharing options...
Ladd Posted March 22, 2008 Report Share Posted March 22, 2008 Strip your bike to bare frame bolt the tool to the bb put the bb tool and clamp it in vice turn the frame and out comes bb worked every time were i work never been beaten bye not getting a bb out. Quote Link to comment Share on other sites More sharing options...
cai Posted March 22, 2008 Report Share Posted March 22, 2008 the mofo still wont come offDo you mean it just turns around but doesn't actually come outwards? Or that its proper stuck, and won't budge? Quote Link to comment Share on other sites More sharing options...
Fixed Pantsâ„¢ Posted March 23, 2008 Report Share Posted March 23, 2008 Chances are you've f**ked your frame by blow torching it.Make sure you're turning the right way is the best advice in this thread. Quote Link to comment Share on other sites More sharing options...
..::littlesam::.. Posted March 23, 2008 Report Share Posted March 23, 2008 Brute force Sam X Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted March 23, 2008 Report Share Posted March 23, 2008 Get some PlusGas Dan, places like Halfords sell it, penetrates and loosens rusted parts.Only other tip I can recommend is what Muel said, and that is bolting the tool in place to make sure it doesn't slip so you can put maximum force on it. Quote Link to comment Share on other sites More sharing options...
Monty99 Posted March 23, 2008 Report Share Posted March 23, 2008 try hammering carefully with a screwdriver against the shell...one or two (opposite) spots should be enough to loose it up a bit. this method helped me with my square taper. good luck Quote Link to comment Share on other sites More sharing options...
Muel Posted March 23, 2008 Report Share Posted March 23, 2008 Blowtorching it would have expanded it in the frame, making it grip more, but it could have actually flared or warped the bb shell slightly as well. Quote Link to comment Share on other sites More sharing options...
dan_addison Posted March 23, 2008 Report Share Posted March 23, 2008 Get some muscles. The beefest rachet and extension bar combo. Should do the trick Quote Link to comment Share on other sites More sharing options...
dan more Posted March 23, 2008 Author Report Share Posted March 23, 2008 thanks for the tips my dads pretty beasty with stuff like this so he should be able to get it out for me so i can ride if not looks like im saveing my pocket muney up for a new frame lol dan Quote Link to comment Share on other sites More sharing options...
Tomm Posted March 23, 2008 Report Share Posted March 23, 2008 Blowtorching it would have expanded it in the frameWell yes, but the shell, being aluminium rather than steel, will expand more so it should work in theory. Quote Link to comment Share on other sites More sharing options...
mintsauce96 Posted March 23, 2008 Report Share Posted March 23, 2008 Best advice for removal is already in the thread, but I can offer a tip for when you eventually get it out and come to fit a new one....... Copperslip Kev Quote Link to comment Share on other sites More sharing options...
Nickkkkk Posted March 29, 2008 Report Share Posted March 29, 2008 (edited) (hope this is a square taper dude) I had a very stiff BB once and i had tried everything with my tool. and i left my farmer boy step-dad to have ago. He has one go with the BB tool and just stopped! Grabbed his welder and welded the axle to the cap of the BB. Then grabbed a monkey wrench (stillsons) and it came of quite easily. Give that a go.Nick Edited March 29, 2008 by eastmartonmassiff Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted March 29, 2008 Report Share Posted March 29, 2008 I had a right hassle getting a BB out of an XC frame the other day. I just poured boiling water all over the BB shell and it came out straight away... wasn't expecting it to work but there you go Quote Link to comment Share on other sites More sharing options...
Nickkkkk Posted March 29, 2008 Report Share Posted March 29, 2008 I had a right hassle getting a BB out of an XC frame the other day. I just poured boiling water all over the BB shell and it came out straight away... wasn't expecting it to work but there you go I would't expect that to work. Im gonna try that next time as its harmless to the bike lolNick Quote Link to comment Share on other sites More sharing options...
