0zzy Posted March 20, 2008 Report Share Posted March 20, 2008 (edited) i already have my front brake sorted (vee btw) its a avid sd5 lever,clarks cable, and sd7 arms with standard pads on a smooth rim. now i wana try it out on the back i already have a sd5 lever so all i want to know is what arms, cable and pads (have to be for smooth rim) for the rear i got around 40 quid to spend tops. i was thinking of clarks brake cable, sd7 arms and some heatsink pads that are suitable for a smooth rim. will that set up be fine or are there better rear vee brakes for the money... ?cheers in advance ozzy! Edited March 20, 2008 by 0zzy Quote Link to comment Share on other sites More sharing options...
spartan Posted March 20, 2008 Report Share Posted March 20, 2008 You can juggle a little where u wanna spend the money.I run avid ultimate arms with rock blue pads and plain deralluer(sp?) housing.If you want ritzy cables the nokon sleeved ones are really nice.If i were you i would suggest avid sd7 arms with vfly pads or the rock greens with either shadow conspiracy or deralluer cables. should be mint man vees are the bomb!Hope this helps,Ian Quote Link to comment Share on other sites More sharing options...
0zzy Posted March 20, 2008 Author Report Share Posted March 20, 2008 cheers mate sounds good, how you finding your vee brake mate? Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted March 20, 2008 Report Share Posted March 20, 2008 i'v got an sd5, xt cable (pretty cheap from thewoolyhatshop) and heatsink reds tis reet good...but i wouldn't trust it in the rain without a grind! Quote Link to comment Share on other sites More sharing options...
0zzy Posted March 20, 2008 Author Report Share Posted March 20, 2008 (edited) ok im most likely (SP?) going to be going for the sd7 arms unless some one knows of anythign better for the price. brake pads are going to be neco reds thanks kris and now all i need to know is what cable for the rear. ? Edited March 20, 2008 by 0zzy Quote Link to comment Share on other sites More sharing options...
cai Posted March 20, 2008 Report Share Posted March 20, 2008 (edited) (have to be for smooth rim)Whap out the grinder and get some CRV's, like me EDIT: brake pads are going to be neco reds thanks kris that'll be a beast! Edited March 20, 2008 by cai Quote Link to comment Share on other sites More sharing options...
0zzy Posted March 21, 2008 Author Report Share Posted March 21, 2008 EDIT: that'll be a beast!it will be a beast. brake sorted now! unless some on can persuad me to get something better for the money. Quote Link to comment Share on other sites More sharing options...
