Disc Bodge
nicks
You could do it, but it would be shite as the piston in a deng lever, (or maggy lever), would be bigger than in a disc lever.
Also it would be a closed system, so you'd constantly be fiddling with the TPA, and it wouldn't be very powerful.
I did run a magura louise disc with an HS33 lever and it worked fine without fiddling with the tpa too much.
I also didn't notice any loss in power.
I think if i'd used it for anything other than trials, the tpa issue may have been more of a problem as the fluid heated up.
The other thing to be careful of is what oil you bleed it with as HS33s only like mineral oil - not sure about denguras though.
Cheers,
Jamie
