2k8-looney Posted March 18, 2008 Report Share Posted March 18, 2008 Hey ridersNedd a bit of help my front brake isnt working to good and i was woundering what would help it become stronger without slipping ?cheers steve Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted March 18, 2008 Report Share Posted March 18, 2008 Is it a disk?a V?or a magura? Quote Link to comment Share on other sites More sharing options...
dan_addison Posted March 18, 2008 Report Share Posted March 18, 2008 guessing its not a disc if its slippingif its a v mess around with the cableif its a magura bleed it Quote Link to comment Share on other sites More sharing options...
2k8-looney Posted March 18, 2008 Author Report Share Posted March 18, 2008 Oh ye sorry its a magura Quote Link to comment Share on other sites More sharing options...
cox. Posted March 18, 2008 Report Share Posted March 18, 2008 Smooth rim or a grind, use some tar. (: Smooth rim, deodorant If you use tar, make sure you clean it every now and then. Just a bit of warm water and a sponge gets it off. x Quote Link to comment Share on other sites More sharing options...
monty221pr Posted March 18, 2008 Report Share Posted March 18, 2008 Iv heard Heatsink reds help this problem Sam. Quote Link to comment Share on other sites More sharing options...
2k8-looney Posted March 18, 2008 Author Report Share Posted March 18, 2008 They are smooth rims Does deoderant actually work ?cheers for the help lads Quote Link to comment Share on other sites More sharing options...
nicks Posted March 19, 2008 Report Share Posted March 19, 2008 Re bleed it, get better pads like plazmatics and titen the lever Quote Link to comment Share on other sites More sharing options...
Tall_Rob Posted March 19, 2008 Report Share Posted March 19, 2008 Get a new brake Steve...... The one you've got has seen better days..I don't actually think it will get better.Easiest fix.... TAR.Rob Quote Link to comment Share on other sites More sharing options...
banashapan Posted March 20, 2008 Report Share Posted March 20, 2008 (edited) are you using a brake booster with it?similar problem i had on an old T-Rex frame i used to have, the magura would flex the seat stays outwards, thus, reducing how effectively the brake worked, the addition of a booster worked a treat. but this may not be the case with forks probably best to start off with a re-bleed and softer pads and see how you get on Edited March 20, 2008 by banashapan Quote Link to comment Share on other sites More sharing options...
2k8-looney Posted March 20, 2008 Author Report Share Posted March 20, 2008 Well dont need to make them better getting an adamant a3 that will have good brakes Quote Link to comment Share on other sites More sharing options...
