My Pads Keep Slipping On My Grinded Rim.
Nickkkkk
My pads are slipping on my rim in the dry (even more so in the wet) What pads are cheap, long lasting and has a bite that wont slip when i gap or just simply back-hop.
maybe i shouldnt of made a whole new thread but i thought this would of got more attension :unsure:
Nick
Edited by eastmartonmassiff
yup make sure they're set up properly, that the length of the pads sit squarely onto the rims...
Also when you press the lever make sure the whole length of the pad touches the rims at the same time
Not one faster den the other....if it does it means your pads are slanted. Make sure to make them straight.
That should solve your slipping problems....
Might wanna try...heatsinks...
for me, the old echos work well.
Oh yes make sure your rims are not contaminated with polish or oil.
lol grinded
Depends what pads your using at the moment and how warn your grind is and how well your brake is set up, as said by others.
Lol, warn
Other than what others have already said, just whack a bit of tar on it, 'be rate :)
What pads are you running and how worn is the grind.
It may need regrinding as the grind wears off after a while.
I think the pads are onza limeys or onza citrus.(there yellow). I only grinded the rear rim 1-2 weeks ago. I ride an Echo Team. Thanks for all the comments.
Nick
I dont use tar because i think ride alot in the rain. and i have allowed my pads to wear out abit unevenly on the rim. (so one side connects before the other one. so i swapped the pad round to get them even again) i dont know if that does anything
Nick
citrus pads are mental, grind needs to be realy light though. you got a booster?
Yeh front and rear brake boosters. The grind isnt to sharp, but even if it was it should still hold lol. i mite just buy some of those adamant ones of tartybikes £9
Nick
Nick
I say get a fresh grind by yourself some heatsink snowys of trials-uk, set them up perfect run untill the start to not bite, clean rim with clean water and sand pads down a bit then but tar on pads then your sorted for LIFE my friend ;)
You will thank me somday :-
xx
