spotty trials kid Posted March 15, 2008 Report Share Posted March 15, 2008 (edited) Hi there all i was just wondering what is the best setup for my rear magura e.g grind or tar etcthanks Elliot Edited March 15, 2008 by spotty trials kid Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted March 15, 2008 Report Share Posted March 15, 2008 A good bleedPads set up close to the rimAnd some hard compound pads and a good grind!A Brake like that will never fail you! Quote Link to comment Share on other sites More sharing options...
Oli Smith Posted March 15, 2008 Report Share Posted March 15, 2008 Your Magura Bled with Magura Royal Blod - not all the crap like water and other crap alternatives..I light sharp grind, which give your pads more grip in the wet or muck etc etc..Some hard big pads, I like Rockpad Blues.. F**kin amazing or a pair from the heatsink range..oli Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted March 16, 2008 Report Share Posted March 16, 2008 HAVE A WATER BLEED! Quote Link to comment Share on other sites More sharing options...
Ladd Posted March 16, 2008 Report Share Posted March 16, 2008 Water bleed maggie, Light sharp grind, Rock Blue pads Quote Link to comment Share on other sites More sharing options...
Sam F Posted March 16, 2008 Report Share Posted March 16, 2008 Good bleed, proper set up with heatsink coust pads in cnc backings with a nice light grind. Works a treat i tell you. Quote Link to comment Share on other sites More sharing options...
GHETO Posted March 16, 2008 Report Share Posted March 16, 2008 Nowt wrong with a good old water bleed!its cheep and simple and does the same job aswel as magura blood!a good grind works wonders and a tiny little bit of tar on the rim not much at all just a tinny patch!should work its maggic! Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted March 16, 2008 Report Share Posted March 16, 2008 Your Magura Bled with Magura Royal Blod - not all the crap like water and other crap alternatives..I light sharp grind, which give your pads more grip in the wet or muck etc etc..Some hard big pads, I like Rockpad Blues.. F**kin amazing or a pair from the heatsink range..oliwater bleed rules Quote Link to comment Share on other sites More sharing options...
Peperami Posted March 16, 2008 Report Share Posted March 16, 2008 water bleed rulesUnless its really cold... Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted March 16, 2008 Report Share Posted March 16, 2008 Unless its really cold...... But then if you keep the brake/water in motion it won't freeze! Quote Link to comment Share on other sites More sharing options...
Sidehop Stuart Posted March 16, 2008 Report Share Posted March 16, 2008 Hi there all i was just wondering what is the best setup for my rear magura e.g grind or tar etcthanks Elliot No one needs to use tar if their brakes are set up correctly.If your hydraulics are still set up correctly, but are failing then try changing pads and/or having a light grind. Quote Link to comment Share on other sites More sharing options...
nicks Posted March 24, 2008 Report Share Posted March 24, 2008 good bleed, heavy grind, no tar, good pads. Quote Link to comment Share on other sites More sharing options...
Muel Posted March 24, 2008 Report Share Posted March 24, 2008 Everyone says that Rock Blues are brilliant, but I've had them twice on two seperate bikes, and they were pretty crap.That was with a hefty grind, water bleed, and a posh lever blade in one case. Quote Link to comment Share on other sites More sharing options...
Callum-Luvs-Trials Posted March 24, 2008 Report Share Posted March 24, 2008 05 maggie with cnc lever, With water bleedHeatsink Reds in cnc backings on a harsh, long lasting and sharp grind.Cnc mounts.And get your pads set-up propley Quote Link to comment Share on other sites More sharing options...
Sam Ward Posted March 24, 2008 Report Share Posted March 24, 2008 Notice that most people say different things.Its all about personal preferance and riding style.Don't ask what the best set up is, go and find out yourself. It takes very little time to set your brake up nicely and pads are hardly expensive, and if you don't like them im sure you'll be able to find someone you can swap them with Quote Link to comment Share on other sites More sharing options...
El Cristoff Posted March 24, 2008 Report Share Posted March 24, 2008 ... But then if you keep the brake/water in motion it won't freeze!Ever tried it, seriously, that doesn't work. and when it freezes, it pushes the pads out on to the rim so you cant even walk it home. Quote Link to comment Share on other sites More sharing options...
mcinnes Posted March 25, 2008 Report Share Posted March 25, 2008 (edited) Decent water bleed, fresh grind ( with tar when it wears down ), decent pads (heatsink reds is the set i am running at the moment although they never worked untill i set them up perfectly) and finally, good working slaves/pistons.Ever tried it, seriously, that doesn't work. and when it freezes, it pushes the pads out on to the rim so you cant even walk it home.I had that problem tonight when i was out riding. The brake only locks to the rim if there is next to no air in the system. Edited March 25, 2008 by mcinnes Quote Link to comment Share on other sites More sharing options...
