Need A Bit Of Help On What To Upgrade To
2k8-looney
Hello
At the moment i ride a mission prodigy its my first trials bike and i have been riding for about three months now and would like to upgrade to a better bike ?
I would like to stay 20" so what would you guys recomend ?
My buget is around £500
Cheers
steve
Second hand you could get a really nice bike for £500.
I sold this for £450 not so long ago.
FRAME: Your choice, 06 short or 07 long.
FORK: 2006 Echo Lite Disc.
FRONT BRAKE: 2005 Hope Mono Trial 160mm.
REAR BRAKE: It's a 2007 Eisbar HS33, Echo Mounts, Echo Booster, Rock Pads, Adamant Lever, Water Bleed. It will have a metal TPA as well.
FRONT WHEEL: Onza Double Drilled Hog Rim on Sealed T-Master Hub.
FRONT TYRE: Try-All.
REAR WHEEL: 2006 Monty 221TI Hub on Try All rim.
REAR TYRE: Maxxis Creepy Crawler.
BAR: Monty 221PR.
STEM: Try-All 31.8mm.
HEADSET: FSA Equipe Pro.
CRANKS: Echo 6061 160mm.
BOTTOM BRACKET: Onza Square Taper.
FREEWHEEL: Monty 18t.
PEDALS: DMR V8s.
In that pic it had the 07 frame attached, but I sold it with the 06 frame.
Hi
I am in the same postiotion as you, i have a mission prodigy and wish to upgrade.
If my budget was asbig as yours, i would get this ....... http://www.tartybikes.co.uk/product.php?id=2180
It has a decent spec and front and and back Magura HS33s
If you wish to buy second hand, keep an eye on this ....... http://cgi.ebay.co.uk/monty-221pr-trials-b...bayphotohosting
There are loads of great second hand bikes on ebay, keep looking every day. :D
Edited by spam-trials
Its an anoying position to be in isnt it
That is a nice bike but i am looking for something like a echo lite or adamant a3 like i saw on the classified chat
Steve
Yeah it is lol.
Erm, ok then, well that monty on ebay is quite nice.
If you were willing to bump up your budget by £175, you could get the nicest bike on the market at the moment, hardly used on ebay ....... http://cgi.ebay.co.uk/Koxx-XTP2-Trials-bik...tem170202011053
Just an idea, u will never need to upgrade unless you want to upgrade to 26 inch or you snap the frame! lol :D
With £500 you could easily build yourself a nice mod bike.
You could build a really good bike with carefull budgeting and a mix of new and second hand parts.
Allways worth keeping an eye on the sales section here, mayeb even PM people if you cant post there (not sure if you can PM as a pre member)
I would reccamend the Adamant A1 or the GU, both ride very nicely
