Mobile Phone Games
Caleb
Driver: http://uploaded.to/?id=u8j08i
BitPim: http://sourceforge.net/projects/bitpim
a. Unpack the drivers to a folder (exp. Desktop), but don’t install it!
b. Install BitPim.
1. You must entering follow code: *#0523#
2. [9] common >> [6] USB Configuration >> [2] Qualcomm USB[*]
--> Qualcomm USB Configured.
please Reconnect the Cable.0
3. Now put the USB cable in the phone and Pc.
--> Windows found a new hardware.
Install the hardware manual and chose the Qualcommdriver folder.
Now go to the Hardware manger ->Modems->Qualcomm, you must know the port number.
4. Open “BitPim” and configure the software for your u700.
Phone type: Other CDMA phone
Com port: *look at step 5*(you can Browse, but chose the right one!)
And press “OK”
5. Start “BitPim”, go to the menu “View” and active “View Filesystem”.
6. Klick on “Filesystem” (left in BitPim).
Now can you see a blue folder, open the folder (press on “+”).
--> … retrieving
7. Now put the games (jar and jad files) in the follow folder “Games” (Media->Games).
8. Disconnect the USB cable from the phone.
9. Leave the Qualcomm menu and entering this code in your u700: *#6984125*#
Now are you in “Admin setting” menu.
a. Select the menu [4] Internals (Master Key: *#9072641*#)
b. Chose the menu [7] Storage settings
c. Update media database, Update Java DB and Create AX that File.
That's it (You can leave “Admin setting”.)
Important: DON’T delete the games with the mobile phone, you must delete the games with “BitPim”.
