Rick_59 Posted March 8, 2008 Report Share Posted March 8, 2008 front rim brake or disk? what do u lot think? Quote Link to comment Share on other sites More sharing options...
spartan Posted March 8, 2008 Report Share Posted March 8, 2008 Dude depends on your set up.Front discs are way more expensive than vees but i think its worth the extra.My Juicy 7 feels... is lush the word in the UK Quote Link to comment Share on other sites More sharing options...
Ladd Posted March 8, 2008 Report Share Posted March 8, 2008 I would run a front bb7 mate not to expensive you could pick up a hole brake for about £55, But if you dont have the forks or disc hub you will need to buy all that wich works out a fair bit, maybe a new set off pads on the magura front brake also a new grind and make sure the pads are set up well Quote Link to comment Share on other sites More sharing options...
Headley Posted March 8, 2008 Report Share Posted March 8, 2008 front disk are deffinatly more popular. Avid bb7's are are great if your looking for a cheap one - £55. You can't go wrong; easy set up, no bleeding/re-bleeding, all round a brilliant brake. Quote Link to comment Share on other sites More sharing options...
dan_addison Posted March 8, 2008 Report Share Posted March 8, 2008 Does no one search. Ive been on this forum 3 days and seen about 9 of these threads Quote Link to comment Share on other sites More sharing options...
Gandalf the Yellow Posted March 8, 2008 Report Share Posted March 8, 2008 if you run a shit rim then get disc, cos it buckles all the time. otherwise get some rim brakes for lightness steve Quote Link to comment Share on other sites More sharing options...
Muel Posted March 8, 2008 Report Share Posted March 8, 2008 (edited) if you run a shit rim then get disc, cos it buckles all the time. otherwise get some rim brakes for lightness steve Edited March 8, 2008 by Muel Quote Link to comment Share on other sites More sharing options...
COCKY Posted March 9, 2008 Report Share Posted March 9, 2008 GET A DISC AND IT WILL WORK IN THE WET GET ONE OFF TRIALS-UK.CO.UK Quote Link to comment Share on other sites More sharing options...
Z o o !! Posted March 9, 2008 Report Share Posted March 9, 2008 GET A DISC AND IT WILL WORK IN THE WET GET ONE OFF TRIALS-UK.CO.UKWHY DID YOU WRITE THAT IN CAPITALS ITS LOOKS LIKE YOUR SHOUTING ?On another note, Front disc has always seemed a mkore popular coice but now front rim brakes seem to be making a come back, front magura is used by alot of top riders aswell as vee's. It all comes down to personal prefrance, Front maguras are beasts when they are set up with decent pads, grind and a bleed. Same goes for vee, decent pads,cable and lever. Id say front magura as i find my bb7 abit too visous, il be changing to front maggie soon. Quote Link to comment Share on other sites More sharing options...
gu trials Posted March 10, 2008 Report Share Posted March 10, 2008 i found out that disks are a lot easier to fray than magura on the front so i would go with a bb7 and plus it wil work better in wet than rim brake Quote Link to comment Share on other sites More sharing options...
nicks Posted March 26, 2008 Report Share Posted March 26, 2008 well if you already have a rim break you will need a new hub and forks but disk brakes are much better. Quote Link to comment Share on other sites More sharing options...
angrybeaver23 Posted March 26, 2008 Report Share Posted March 26, 2008 Front disc is a much better idea as rim brakes can be rubbish in the wet and too snappy for stoppies etcabut just be carefull abour pranging you disc as it could be expensive especially if you tend to prefer sidehops up to the left etc! Quote Link to comment Share on other sites More sharing options...
Control-Trials Posted March 27, 2008 Report Share Posted March 27, 2008 I run a Front Magura. Performence isn't great at the moment. Saying that, I havn't touched my bike in two years.Current set up is: Magura HS33, Plaz pads smooth rim. Think im going to upgrade a Hope mono Trials soon. Not to sure, because that means i've got get a new front hub and disc forks. Quote Link to comment Share on other sites More sharing options...
