Bit Of Help Here - Plugs, Fuse Holders, Materials, Bs Numbers..
JonMack
pretty sure urea formaldehyde or ABS are the weapons of choice....you want electrical resistance, rigidity for support, tough (for protection)
UF is a thermosets (as mentioned above)...compression moulded i'd say.. (2 piece old skool plugs)
ABS is a thermoplastic...injection moulded (those..pre-fitted plugs)
Fuse holder is usually copper....good conductor, easy to process
i do materials science :P
adam
