CRANK BRO Posted February 28, 2008 Report Share Posted February 28, 2008 HI guys i should be getting my frame and forks next week and need to spray the frame white.Do all of you spray your own frames?I was going to get it sand blasted then plastic coated but its like getting a company to do it nobody seems bothered in doing it and im not the best at spraying always get runs and i rush things.any ideas please? Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted February 28, 2008 Report Share Posted February 28, 2008 Powder coating generally gives a better finish, is a little more resilient to knocks, and can give a more even coating.Painting (DIY) can be cheaper and easier, plus quicker, and if you're likely to be changing colours a lot this can be appealing. It's also easier to touch up little scratches etc.Professional spray jobs will cost around the same as a powder coat, and have a great finish to them, but will still be a little more prone to chips etc than powder. Quote Link to comment Share on other sites More sharing options...
mike Posted February 28, 2008 Report Share Posted February 28, 2008 powder coating *** way more scratch resistant which is brilliant in trials but spray painting is by far cheaper.if you've got the time and money i'd go for powder coating.hope this helps Quote Link to comment Share on other sites More sharing options...
Conor the basher. Posted February 29, 2008 Report Share Posted February 29, 2008 If you but the stuff from halford it will cost youunder 2o quid 2 or 3 cans of vw candy white ( very nice white) some scouring pads, primer ( if needed) and laquer if you want aswell.The bast thing is to take your time, light coats, plenty of light on the part your spraying so that you can see any runs also ideally you want a well ventilated room to minimize dust cheers conor. Quote Link to comment Share on other sites More sharing options...
CRANK BRO Posted February 29, 2008 Author Report Share Posted February 29, 2008 thanks guys Quote Link to comment Share on other sites More sharing options...
cai Posted February 29, 2008 Report Share Posted February 29, 2008 DIY spraying is very easy, just take your time and build it up slowly.I nitromors'd the frame,Primerd it,Left the primer dry for 48hrs before actually spraying it,Then sprayed it, and it came out really well! Quote Link to comment Share on other sites More sharing options...
Tom Booth Posted February 29, 2008 Report Share Posted February 29, 2008 If your being a tart, flat it with some damp 1600 grit wet and dry, then compound it, then polish it fater paint. Done right and you'll have a finish that will rival any car Quote Link to comment Share on other sites More sharing options...
