Sir_Hops_Alot Posted February 27, 2008 Report Share Posted February 27, 2008 As the title says i'm buying new cranks on friday (echo forged) and i was wondering how hard it is to get the cog off the old cranks, what i need to do to secure it properly and safely? Any tips would be appreciated as i've never done it before. Quote Link to comment Share on other sites More sharing options...
ogre Posted February 27, 2008 Report Share Posted February 27, 2008 dont get echo forged cranks, there apauling. get metas i killed the pedal threads in 2months *anger* on my echos Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted February 27, 2008 Author Report Share Posted February 27, 2008 I can't afford metas mate and all i've heard about echo is they are great! Sum help with my question would have been nice too. Quote Link to comment Share on other sites More sharing options...
cai Posted February 27, 2008 Report Share Posted February 27, 2008 I mucked up the pedal threads on my forged's within weeks!If you can't afford the Metas, Get the T-pro (tapered) cranks - even though they're tapered, there awsome! And come with a free bash.Check the wiki for advice with cogs. Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted February 28, 2008 Author Report Share Posted February 28, 2008 Will i need any lock tight or anything like that to make a secure hold on cog when i'm done? Quote Link to comment Share on other sites More sharing options...
Radfax Posted February 28, 2008 Report Share Posted February 28, 2008 Its bloody near impossible Chris! The last two i took off (ACS's because i had snapped pawls) i had to take off with a grinder because they are like erm stuck on so solid! I only ever got one off and that was on an old megamo crank when they used to be popular years ago! And i completely wrecked the thread on both crank and freewheel! What freewheel are you using again? tensile? Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted February 28, 2008 Author Report Share Posted February 28, 2008 Yeah am running a tensile freewheel, will i ahve to buy cog aswell then? Quote Link to comment Share on other sites More sharing options...
Tomm Posted February 28, 2008 Report Share Posted February 28, 2008 Do you mean cog (screw on sprocket) or freewheel on the front? For sprockets you need to use a chainwhip and a long pole. Clamp your cranks in a vice and use the pole on the chainwhip for leverage. Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted February 28, 2008 Author Report Share Posted February 28, 2008 Yeah i mean a screw on sprocket when i say cog mate, i've looked in the wiki section and there is a way around the chain whip so i'm going to try that instead. Quote Link to comment Share on other sites More sharing options...
Radfax Posted February 28, 2008 Report Share Posted February 28, 2008 humm well, i used to put my crank into a vice and wack the pokey out bits on the freehweel which you would put the freewheel removal tool on untill it came loose, it absoloutley lkilled them bits and took a while to come off but it didnt effect the freehweel, i used to try it with a whip and pole but only evern ended up in a heap on the floor! No you can get them off and you dont need to buy a new one. If you need a hand id be more than happy to help you out although the whip way is right i just found it to be a complete cock up! Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted February 28, 2008 Author Report Share Posted February 28, 2008 Cheers mate i'd proberly fit them saturday if they arrive but i'll give it ago, i just want to run both of my new pedals lol Quote Link to comment Share on other sites More sharing options...
Radfax Posted February 28, 2008 Report Share Posted February 28, 2008 haha! well if you have a problem or whatever bring um down and ill lend a hand or whatever! Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted February 28, 2008 Author Report Share Posted February 28, 2008 Give me a hand to push the bloody things off lol Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted February 28, 2008 Report Share Posted February 28, 2008 your best to buy another cog there about £12 arent they? Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted February 28, 2008 Author Report Share Posted February 28, 2008 Yes but i don't have £12, and its proberly not as hard as people make out. Quote Link to comment Share on other sites More sharing options...
mike Posted February 29, 2008 Report Share Posted February 29, 2008 if you use the chain whip method, your better off using the longes pole you can otherwise you'll be putting all your weight onto it, and when it does come loose (or skips) you'll end on the floor like radfax said, if you get enough leverage, you should be able to just pull it.a good tip is to try keep the pressure on it and build it up rather than like a sharp jolt (i.e hitting it with a hammer thats the last option)good luck! let us know how it goes. Quote Link to comment Share on other sites More sharing options...
Greetings Posted February 29, 2008 Report Share Posted February 29, 2008 http://www.trials-forum.co.uk/forum/index....showtopic=94909 Quote Link to comment Share on other sites More sharing options...
Muel Posted February 29, 2008 Report Share Posted February 29, 2008 Hang on, are you running a freewheel or a sprocket? Because you have said you run both.To get a freewheel off, get the proper tool, bolt it into the crank and lamp the tool up in a vice.Then, put a piece of old innertube over the crank arm to stop it getting scratched, spil a long pole over the crank arm and undo it, I think it comes off anti clockwise. Think of it as, it tightens when you drive the pedals forward, so you need to turn it the other way. Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted February 29, 2008 Report Share Posted February 29, 2008 What do you guys do to your Echo cranks to mess up the pedal threads?! The only way to do that is to continue riding with loose pedals surely? Which means it's nothing to do with the cranks... I've been running Echo forged cranks on my 24 for about 4 months now without any problems whatsoever.Anyway, good luck getting the sprocket off... those things can be really difficult to remove although with enough leverage and possibly the correct application of heat it can be done without too much hassle. Quote Link to comment Share on other sites More sharing options...
