Which Way Does My Disc Go On? =|
Rob Brodie
anti, but it doesnt really matter
Nah it kinda does. The force of the brake stopping the rotor is fairly strong, so the curves facing the other way are stronger than if they were facing the force? Hope you understand that... I can't explain anything well today.
That's how I'd have described the correct way to fit a disk too... Most disks are set up with non radial spokes linking the rim/braking surface of the disk to the area that bolts to the hub. Since the spokes dont extend radially from the hub of the disk, a braking force applied to the rim of the disk will either have the effect of pulling the braking surface towards the hub or away from it. It doesn't really matter for most setups in trials though. Especially for back disks where the brake will get loaded hard in both directions anyway - not the front brakes have it particularly easy on trials bike either :)...
