Kieran@ZSClothing Posted February 26, 2008 Report Share Posted February 26, 2008 (edited) Hey im buying some new seats for my mini its a old mini like 19 years old whould the Corbeau Motorsport Seats fit?if so how easy to install are they? cheer's. Edited February 26, 2008 by Lab Rat Quote Link to comment Share on other sites More sharing options...
Tom Booth Posted February 26, 2008 Report Share Posted February 26, 2008 Are they side mount seats ? Look it. The'll be a doddle to fit, the'll be fixxed in position thou so make sure you are comfortable where the seat it. They wont slide! Quote Link to comment Share on other sites More sharing options...
Kieran@ZSClothing Posted February 26, 2008 Author Report Share Posted February 26, 2008 Yeah i think wear i sit is fine but is there no way i can make it slide?cheers. Quote Link to comment Share on other sites More sharing options...
Mr_scott Posted February 26, 2008 Report Share Posted February 26, 2008 Theres always a way, you just have to invent it if not already.Whats the width from sholder to sholder on the seat?You might have a problem getting them sitting side by side,if you get me. ? Quote Link to comment Share on other sites More sharing options...
Tom Booth Posted February 26, 2008 Report Share Posted February 26, 2008 I severely doubt it. There might be some sort of adapters to make a side mount fit a subframe, but you'r better off just buying subframe mounted seats? Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted February 26, 2008 Report Share Posted February 26, 2008 They look fairly wide to me...I have some pretty wide buckets that I bought for my Mini, but I didn't think about the width.They do go in, but they're huge, and rub together, and on the insides of the car, so I just took them out in the end. Quote Link to comment Share on other sites More sharing options...
Kieran@ZSClothing Posted February 26, 2008 Author Report Share Posted February 26, 2008 I severely doubt it. There might be some sort of adapters to make a side mount fit a subframe, but you'r better off just buying subframe mounted seats? Sorry im a complete car retard dont no what a sub mounted seat is? there looks like there will be enuf room for both seats .cheers.I just found these and they look smaller and allot cheaper.any good? Quote Link to comment Share on other sites More sharing options...
Peperami Posted February 26, 2008 Report Share Posted February 26, 2008 I severely doubt it. There might be some sort of adapters to make a side mount fit a subframe, but you'r better off just buying subframe mounted seats?Most sidemounts will be designed to fit to subframes mate, rather than just to the floor itself.People bolt them direct to the floor to lower the seating position. Quote Link to comment Share on other sites More sharing options...
Tom Booth Posted February 26, 2008 Report Share Posted February 26, 2008 Right, A subframe mounted seat, means a seat, thats on a frame, usually allowing for sliding and tilting in the seats. Thats a subframe, as you can see, it allows the seat to move foward and backwards on the sliders.Side mounted bucket seats, such as the ones you posted, are bolted directly to the floor pan, via brackets. As you can see, the brackets are alread on there, and that just bolts directly to the floor. Quote Link to comment Share on other sites More sharing options...
Peperami Posted February 26, 2008 Report Share Posted February 26, 2008 Sorry im a complete car retard dont no what a sub mounted seat is? there looks like there will be enuf room for both seats .cheers.I just found these and they look smaller and allot cheaper.any good?The cheaper seats are, the less comfy they are. Those look like they'd give you a numb ass in no time at all.Right, A subframe mounted seat, means a seat, thats on a frame, usually allowing for sliding and tilting in the seats. Thats a subframe, as you can see, it allows the seat to move foward and backwards on the sliders.Side mounted bucket seats, such as the ones you posted, are bolted directly to the floor pan, via brackets. As you can see, the brackets are alread on there, and that just bolts directly to the floor.Lol, no the sidemount brackets will then mount to a subframe mate. You can bolt them directly to the floor though, lowers the position but you lose all adjustability.Its usually only cheaper seats that are subframe mounted (without sidemounts) Quote Link to comment Share on other sites More sharing options...
Tom Booth Posted February 26, 2008 Report Share Posted February 26, 2008 Most sidemounts will be designed to fit to subframes mate, rather than just to the floor itself.People bolt them direct to the floor to lower the seating position.I know why people direct them to the floor, but I did'nt know about the possibility of subframe mounting too, The ones he posted in the origional post thou look like a CF shaped seat, which I doubt could be mounted on a subframe.My friend uses the Forza's you posted in his mini, there nice seats, Comfy. Without getting personal, what sort of waist width are you? Aslong as your under a 40" waist you'll be fine with buckets. Are you going with Harnesses aswell?Lol, no the sidemount brackets will then mount to a subframe mate. You can bolt them directly to the floor though, lowers the position but you lose all adjustability.Ah right, I didnt realise the bolt's would line up, Never really had given it a thought! Quote Link to comment Share on other sites More sharing options...
Kieran@ZSClothing Posted February 26, 2008 Author Report Share Posted February 26, 2008 Cheers for all the help people im a 17 year old skinny bitch lol Quote Link to comment Share on other sites More sharing options...
Peperami Posted February 26, 2008 Report Share Posted February 26, 2008 I know why people direct them to the floor, but I did'nt know about the possibility of subframe mounting too, The ones he posted in the origional post thou look like a CF shaped seat, which I doubt could be mounted on a subframe.My friend uses the Forza's you posted in his mini, there nice seats, Comfy. Without getting personal, what sort of waist width are you? Aslong as your under a 40" waist you'll be fine with buckets. Are you going with Harnesses aswell?Ah right, I didnt realise the bolt's would line up, Never really had given it a thought!Ye, otherwise you'd have to jack car up and unbolt the seats everytime you wanted to move closer/ further from the wheel!Quite a few people with minis use cobra clubman seats i think.Are they gonna be used for road/ track fella? Quote Link to comment Share on other sites More sharing options...
Kieran@ZSClothing Posted February 26, 2008 Author Report Share Posted February 26, 2008 I think i have like to poles coming out the floor and the seat just bots onto them im no to sure but thats what it looks like.whould the seat some with clamps so i can just bolt them onto it?cheers.Ye, otherwise you'd have to jack car up and unbolt the seats everytime you wanted to move closer/ further from the wheel!Quite a few people with minis use cobra clubman seats i think.Are they gonna be used for road/ track fella?ROAD. Quote Link to comment Share on other sites More sharing options...
Tom Booth Posted February 26, 2008 Report Share Posted February 26, 2008 Truth, Danny uses them. Quote Link to comment Share on other sites More sharing options...
Peperami Posted February 27, 2008 Report Share Posted February 27, 2008 (edited) I think i have like to poles coming out the floor and the seat just bots onto them im no to sure but thats what it looks like.whould the seat some with clamps so i can just bolt them onto it?cheers.Lol, ive only ever set-up track clio's, never stripped a mini, but guessing the seat mountings cant be too different.Is there not a mini forum to ask on? lol Edited February 27, 2008 by Peperami Quote Link to comment Share on other sites More sharing options...
Tom Booth Posted February 27, 2008 Report Share Posted February 27, 2008 I have no idea about the 2 poles comming out the floor....But you should have on the cross member 2 seat mounts per side,with a nut and bolt in each. Then next to the exhaust tunnel, a rail that bolts down on the floor at each end. Quote Link to comment Share on other sites More sharing options...
Kieran@ZSClothing Posted February 27, 2008 Author Report Share Posted February 27, 2008 I have no idea about the 2 poles comming out the floor....But you should have on the cross member 2 seat mounts per side,with a nut and bolt in each. Then next to the exhaust tunnel, a rail that bolts down on the floor at each end.Yeah its like 4 poles have been bolted on to hold the seat's on? 2 poles per seat .sorry for my lack of imfomation. Quote Link to comment Share on other sites More sharing options...
Tom Booth Posted February 27, 2008 Report Share Posted February 27, 2008 There the origional seat mounts (cept mine are on the other side). What mini is it out of intrest? Quote Link to comment Share on other sites More sharing options...
Kieran@ZSClothing Posted February 27, 2008 Author Report Share Posted February 27, 2008 (edited) There the origional seat mounts (cept mine are on the other side). What mini is it out of intrest?Mine look nothing liek that ill try get a pic tommorow.Its a austin mini c reg i think.I found one of these online its a Corbeau mounting bracket chould i just put these on the mini so i can agust the seat and clamp it on as well? Edited February 27, 2008 by Lab Rat Quote Link to comment Share on other sites More sharing options...
Radfax Posted February 27, 2008 Report Share Posted February 27, 2008 yeh they should all fit, corbeau Forzas are pretty common in minis so are cobras do as i had a set in my mini. and yes the first will also fit! pretty much 200% certain on that one! Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted February 27, 2008 Report Share Posted February 27, 2008 Ye, otherwise you'd have to jack car up and unbolt the seats everytime you wanted to move closer/ further from the wheel!In motorsport sidemounted seats are usually bolted straight to the floor unless your taking part in some kind of endurance race where you have to change driver.reason for mounting them to the floor is that you want to keep the weight and centre of gravity low and also it's less weight and in some cases you don't go to the trouble of having a kevlar seat molded to the shape of your arse because it's light to go and add 5 kilos a pair with subframes.for just daily driving on the road though cobra clubmans mounted either some homemade frames or straight to the floor in the most comfortable position if it's just you who drives it. Quote Link to comment Share on other sites More sharing options...
Trials Punk Posted February 27, 2008 Report Share Posted February 27, 2008 CORBEAU SPRINTS ARE A B**TCH TO FIT I've got some here. Havn't fitted them yet. Need to cut out the rear door bins and re locate the harness eye bolts near the handbrake for the side mounts to fit nice. Shoulder to shoulder they are very wide. Don't get me wrong nice seats but you'll stuggle to see behind you. Quote Link to comment Share on other sites More sharing options...
Radfax Posted February 27, 2008 Report Share Posted February 27, 2008 i had already cut my bins out so didnt get that problem! Quote Link to comment Share on other sites More sharing options...
Danny Posted February 28, 2008 Report Share Posted February 28, 2008 Truth, Danny uses them.You rang? Quote Link to comment Share on other sites More sharing options...
