Chains For Single Speed
alech
I’m probably going to get a single speed set up for my bike, I’m going to get a dmr revolver ss hub and get an acs freewheel, will a normal chain work, if not will I need a different front chainring if I need a different chain?
ive got a kmc kool chain that i am running on single speed. works a treat and i have had no trouble wots so ever. thumbs up to the kool chains (Y)
Thanks for all the good advice on the chains, but will all of these work with a normal front chainring and an acs claw rear freewheel, as aren't the freewheels designed for bmx's which use a wider chain, suggesting that if you need a wider chain that you need a different front chainring? Please tell me if i'm right?! :) And how did you know i'm validated if that was aimed at me? Cheers!
