nialllove Posted February 22, 2008 Report Share Posted February 22, 2008 hi ive noticed that a lot of people are on about bleebing magura hs33 brakes what does bleeding do and how do you no when to do it also how do you do it???? thanks Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted February 22, 2008 Report Share Posted February 22, 2008 maguras end up spongey and sluggish when there is air in the system, or even if it just an old brake so people put in fresh fluid to sharpen up the system. you can bleed it using two methods, one is with a bleed kit, which is basically a syringe with hoses attached. or using a bath bleed, where you put the wholebrake under water and pump the lever to suck the water inside. Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted February 22, 2008 Report Share Posted February 22, 2008 Ash-Kennard said: maguras end up spongey and sluggish when there is air in the system, or even if it just an old brake so people put in fresh fluid to sharpen up the system. you can bleed it using two methods, one is with a bleed kit, which is basically a syringe with hoses attached. or using a bath bleed, where you put the wholebrake under water and pump the lever to suck the water inside.Only use the syringe if your out on a ride, if your at home use the bath its a lot better and you have not way of geting air in the system Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted February 22, 2008 Report Share Posted February 22, 2008 i always use a syringe, but there is an art to it. also i cant bath bleed as my hose goes through my frame lol Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted February 22, 2008 Report Share Posted February 22, 2008 Ash-Kennard said: i always use a syringe, but there is an art to it. also i cant bath bleed as my hose goes through my frame lolOh right never noticed that before ash i will have a look next time i see you. And how do you manage that as well?? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted February 22, 2008 Report Share Posted February 22, 2008 i ride a gu Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted February 22, 2008 Report Share Posted February 22, 2008 Ash-Kennard said: i ride a guYes ash i do know lol I'm Scott little DA bomb kid lol i have just never noticed it before and i did not know you could run it in the frame lol Quote Link to comment Share on other sites More sharing options...
t-mag boi Posted February 22, 2008 Report Share Posted February 22, 2008 You can either use a sringe or a basin bleed, i would go for the basin bleed as no air can get inmichael Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted February 22, 2008 Report Share Posted February 22, 2008 t-mag boi said: You can either use a sringe or a basin bleed, i would go for the basin bleed as no air can get inmichaelThats basically what i said lol. make something different up Quote Link to comment Share on other sites More sharing options...
Z o o !! Posted February 22, 2008 Report Share Posted February 22, 2008 Syringe can be kind of tricky, as said above theres and art to it, However, i found that if you use a bottle it get more fluid through, i normally to a bath bleed and use the bottle, the advantage of using a bath bleed is when you take the bleed tube out, the water cant escape. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted February 22, 2008 Report Share Posted February 22, 2008 for an amazing bleed*Fill your sink/bath with water*take the bolt out of the lever (not the hose, the other bolt)*take the bolt out of the cylinder*submerge the whole brake in the water*pull the lever several times so there is no air coming out of either hole*screw the water filled syringe into the lever*and push the water throug the system*unscrew the syringe and put both bolts back in, whist still under water!Best Bleeds EVER!Ben Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted February 22, 2008 Report Share Posted February 22, 2008 Benjaminge said: for an amazing bleed*Fill your sink/bath with water*take the bolt out of the lever (not the hose, the other bolt)*take the bolt out of the cylinder*submerge the whole brake in the water*pull the lever several times so there is no air coming out of either hole*screw the water filled syringe into the lever*and push the water throug the system*unscrew the syringe and put both bolts back in, whist still under water!Best Bleeds EVER!BenThanks for that Ben i did not really know how to do it to be honest lol Quote Link to comment Share on other sites More sharing options...
