nialllove Posted February 20, 2008 Report Share Posted February 20, 2008 hiya does anybody no if it is ok to use a good strong tape in stead of a chainstay protector and about how much would it cost for a frame guard thanks niall Quote Link to comment Share on other sites More sharing options...
chrisbikefix Posted February 20, 2008 Report Share Posted February 20, 2008 (edited) you can pick up frame protectors for about 3 quid, or make one out of an old inner tube and a few zip ties, but tape does work, just peals off after a while and leaves loads of sticky shizen on the frame ...i used to use a cut up old tyre for a frame protector ..... with a bit of cut down plastic gutter pipe on the bottom seemed to kind of work Edited February 20, 2008 by chrisbikefix Quote Link to comment Share on other sites More sharing options...
Ben H! Posted February 20, 2008 Report Share Posted February 20, 2008 (edited) see if you can find an armourdillo for the downtube anywhere apparantly aire valley cycles are having a new batch or just get a chainstay protector Edited February 20, 2008 by Czartrials Quote Link to comment Share on other sites More sharing options...
max-t Posted February 20, 2008 Report Share Posted February 20, 2008 No reason why you cant do that mate.Trials-uk Range of Chainstay Protectors Quote Link to comment Share on other sites More sharing options...
