Argh! I Hate Disc Rotors!
Peperami
Was gonna put this in the angry thread, but was too angry to open it...
Why are the bolts holding my hope mono rotor on made of cheese??
Just sliced a chunk of my knuckle off, and rounded off 4 bolts trying to remove it :angry: !!!!!! Now have to faff about with drills and shizzle.
Thinking i might saw the bolts into some sort of flathead, and screwdriver them off :P
You might aswell round off the other 2 bolts, seems a shame you only ruined 4 of them.
Seriously though, after rounding off 2 bolts, didn't you think "Hmmm something's not right here". Respect for making a difficult job really bloody difficult though.
I tried my best but the other two just wouldnt round! :P
To be fair the bolts are utter shit. Torx heads are awful, one tiny slip or slightest bit of pressure and they just give in and then they're f**ked.
I got torx bolts with my hope brakes, they fitted ok but I want to change my rotors...but its probably not worth the stress :) and an angle grinder is going nowhere near my wheels.
These were 4mm hex bolts, were they meant to be torx heads?
Will have a look and see what bolts tarty have sent me with the new rotor, they look less cheesy anyways.
Heavy handed bastards. You 2 would be perfect for working at my place. all people do is round bolts off which i have to fix :@
It realls isnt difficult to use and allen/ torx key. Push, turn anti clockwise, simple..
Next time, stick abit of copper grease in there, stock them chemically welding ;)
peperami i see your on tf nice one dont think you replied to the mtb thread on cs or you did and i missed it.
the bolts are shite you gotta take your time with them, or do what i do and dont bother riding your bike then you wont need to fix it lol.
The original silver hope hex bolts were a bit cheesy. Replace them with a set of their newer black torx ones. Much better.
No they are not. They are stronger than standard allen bolts. Get a decent bit and put it in properly and they wont round.
Lol! I know how to use an allen key fella.
I really can't understand how people can mash/wreck bolts.....
I hope it's just a mix of bad tools and rushing.
I put the allen key in, turned it anti-clockwise, and it span instead of undoing the bolt.
If i understood why it span, i wouldnt have done it!
Hammer
Flat head screw driver
Press the flat head screw driver into the bolt then wack it with the hammer which will form the disc bolt into a flat head then unscrew it.
Cheers mate, will give that a go. If it doesnt work will saw a flathead into it.
You obviously dont otherwise you wouldnt have rounded it off ;)
Probably didn't "Push", but its ok because he knows how to use an allen key (Y)
:giggle:
Lol, ive been riding club level cross country for around 8 years, trials for 2, and have built and tracked a clio race car...
but yeah, which end of the allen key goes in the hole?
Edited by Peperami
The corner bit where the bend is i though...
Im not doubting your vast knowledge of using an allen key, If anything, you should be ruining threads from being manly not killing heads haha.
You can get this threadlock type stuff that is similar to copper grease, but it also adheres to the thread. Cant remember the name of it though
The problem is that a t20 torx driver will sit nicely in a t25 hole. It's only after you've rounded it that you realise you picked up the wrong size. I don't like 'em.
