NVWOCI WVS Posted February 19, 2008 Report Share Posted February 19, 2008 A failed sidehop lead to me crushing one of the bolt holes on my rear pro2. Will the hub be under significantly more stress if i run a rear disc on 5 bolts? Quote Link to comment Share on other sites More sharing options...
max-t Posted February 19, 2008 Report Share Posted February 19, 2008 (edited) It will be fine. You wont though. Rear disc and vegemite Edited February 19, 2008 by max-t Quote Link to comment Share on other sites More sharing options...
Token Posted February 19, 2008 Report Share Posted February 19, 2008 Yeah you'll be fine, Ricky Coleman from Hastings use to run his front disc with 3 bolts, and held the caliper on the mount with just one bolt. Quote Link to comment Share on other sites More sharing options...
aaron chase Posted February 19, 2008 Report Share Posted February 19, 2008 Yeah you'll be fine, Ricky Coleman from Hastings use to run his front disc with 3 bolts, and held the caliper on the mount with just one bolt.also pablo was running recently with 3 bolts on his front disc.dont worry about it Quote Link to comment Share on other sites More sharing options...
TOBY-E Posted February 19, 2008 Report Share Posted February 19, 2008 Yer it should be fine, i ran mine on 3 bolts it just makes a bit off a creaking noise. Quote Link to comment Share on other sites More sharing options...
Adam-Griffin Posted February 19, 2008 Report Share Posted February 19, 2008 I used two on the reading ride and it seemed to be fine for me. Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted February 19, 2008 Report Share Posted February 19, 2008 im running 4bolts on my avid bb7(203mm) ,had no problems yet .steve Quote Link to comment Share on other sites More sharing options...
RossMcd Posted February 19, 2008 Report Share Posted February 19, 2008 im running 4bolts on my avid bb7(203mm) ,had no problems yet .stevesame!only difference is i was running a BB5 Quote Link to comment Share on other sites More sharing options...
Ben Cox Posted February 20, 2008 Report Share Posted February 20, 2008 well i beat you all, im running a 5003" rotor with no bolts! just glue and spunk Quote Link to comment Share on other sites More sharing options...
monkeymoped Posted February 20, 2008 Report Share Posted February 20, 2008 should be ok some downhillers i know including myself run 3 bolts on the rotors, as long as they are kept tight it shouldn't be a problem Quote Link to comment Share on other sites More sharing options...
