Anyone Got Info On Echo 06 Frames?
steve@banbury-trials
hello,i've been looking around for a new frame recently and im interested in the echo control 07 ,i really like the geomentry and evrything so i wanna get one ,thing is ,i've seen some 06's flying around tad cheaper and these frames are almost identical in geomentry ;so here are my questions.
1.are these frames (06)just as strong as the 07's?
2.what is the brake mount spacing?
3.what is the headtube length?
answers are appreciated (Y)
steve
Edited by banbury trials
If you get one, make sure to run a booster for the magura, not too stiff rear end, leaves you with a poor feel on the lever without a booster. I used the 4 bolt heatsink - did the job perfect.
Couldn't tell you the exact brake mount spacing BUT, it was wide enough for a tryall rim and new coustpads with the cnc backings, so wide enough to fit near anything!
only pic I can find of it, was a while ago I had it. Good frames though, I'd recommend!
EDIT : just noticed you said 'Echo Control' ah well its there for anyone that wants it :)
Edited by CraigMackay
