eskimo Posted February 15, 2008 Report Share Posted February 15, 2008 Come across these on the web when i was looking into the MOE pads. Intresting... but i prefer the original yellow. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted February 15, 2008 Report Share Posted February 15, 2008 The red is the original With 60mm long CNC anodised blue backings... Quote Link to comment Share on other sites More sharing options...
Waddy Posted February 15, 2008 Report Share Posted February 15, 2008 The red is the original With 60mm long CNC anodised blue backings...got them in an old MBUK and apparently there too good so not worth getting ha ha Quote Link to comment Share on other sites More sharing options...
Tim/Trialsin USA Posted February 15, 2008 Report Share Posted February 15, 2008 Orginally ('99) they were yellow. First used in CNC backings (black) for HS-33s. Later we added V version using same pad (size and formula). Red was done a couple years later, and intermittently (when yellow pigment was not available). Quote Link to comment Share on other sites More sharing options...
jsy trials matt Posted February 15, 2008 Report Share Posted February 15, 2008 why is there such a little amount of pad? Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted February 15, 2008 Report Share Posted February 15, 2008 why is there such a little amount of pad?You took the wors right out of my mouth! Quote Link to comment Share on other sites More sharing options...
Janson Posted February 15, 2008 Report Share Posted February 15, 2008 i used to have a set of them red crv. brilliant pads. soooo stiff with thick backings and little pad.they lasted long aswell, easily a season back when i rode for 10 hours a week. Quote Link to comment Share on other sites More sharing options...
Callum-Luvs-Trials Posted February 15, 2008 Report Share Posted February 15, 2008 I Have A Set Of The Original And THe Backings............. Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted February 15, 2008 Report Share Posted February 15, 2008 You took the wors right out of my mouth!Oh, it must have been while you were kissin' me(Meatloaf - You took the words right out of my mouth) hahaDanny. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted February 15, 2008 Report Share Posted February 15, 2008 Oh, it must have been while you were kissin' me(Meatloaf - You took the words right out of my mouth) hahaDanny.or when you were kneeing me in the Balls?:| Quote Link to comment Share on other sites More sharing options...
eskimo Posted February 16, 2008 Author Report Share Posted February 16, 2008 The red is the original With 60mm long CNC anodised blue backings...Orginally ('99) they were yellow. First used in CNC backings (black) for HS-33s. Later we added V version using same pad (size and formula). Red was done a couple years later, and intermittently (when yellow pigment was not available).So they were yellow first? I remember back they were yellow but i must of missed the red stage. Quote Link to comment Share on other sites More sharing options...
Tim/Trialsin USA Posted February 17, 2008 Report Share Posted February 17, 2008 (edited) Yes, first they were yellow w/black CNC backings for HS-33s. Later there were some blue anodized backings. Then there were CNC V-brake backings....introduced..... hmmm, its been a long time!....think it was '02 or '03. As mentioned above, intermittently there have been red pads when we could not get them in yellow.There are trade offs when it comes to thickness of pad (the ammount sticking out beyond the backing). The thicker it is, the harder it has to be (or it will be unpredictably squishy feeling). Obviously the reverse is true. While the hardness of a compound is not the predominent determiner of grippiness (nor lifespan), generally speaking harder pads do not grip as well (on smooth/light grind as CR, CRM and CRV were designed for) on these smoother surfaces. Edited February 17, 2008 by Tim/Trialsin USA Quote Link to comment Share on other sites More sharing options...
