Scott Norman Posted February 14, 2008 Report Share Posted February 14, 2008 (edited) what would be better front and rear full wheel builds??meta trials wheel setmetaorviz front and rear?frontrear Edited February 14, 2008 by titty boy Quote Link to comment Share on other sites More sharing options...
max-t Posted February 14, 2008 Report Share Posted February 14, 2008 Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted February 14, 2008 Author Report Share Posted February 14, 2008 sorry hit enter by accident lol Quote Link to comment Share on other sites More sharing options...
cai Posted February 14, 2008 Report Share Posted February 14, 2008 I've never tried anything made by Meta, but I know Viz are good reliable trials products.I'd get the Viz ones, cheaper, and more choice of colour two! Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted February 14, 2008 Report Share Posted February 14, 2008 i would probably say meta they look a bit more stronger of course i could be wrong?of course you could build the wheel yourself and save money or even get tarty to do it they are quite cheap for wheel builds then you would have more choice of hubs spokes and rims that can be suited to your bugdet Quote Link to comment Share on other sites More sharing options...
gasgas rider Posted February 14, 2008 Report Share Posted February 14, 2008 hey mate go for the try-all rims, absolutly perfect for me, and a good range of colour:)x Quote Link to comment Share on other sites More sharing options...
eskimo Posted February 14, 2008 Report Share Posted February 14, 2008 Viz i'll say. Non disk is also available if your not planning on using a disk that is. The bearings are so smooth. I currently run the Viz hubs on the stock as there isn't much on the market. And as far as Echo hubs go, i'd stay away from them. Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted February 14, 2008 Author Report Share Posted February 14, 2008 Viz i'll say. Non disk is also available if your not planning on using a disk that is. The bearings are so smooth. I currently run the Viz hubs on the stock as there isn't much on the market. And as far as Echo hubs go, i'd stay away from them.i properly will be getting a disk so i will properly go disk but I'm still thinking weather to. Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted February 14, 2008 Report Share Posted February 14, 2008 i properly will be getting a disk so i will properly go disk but I'm still thinking weather to.depending on what frame you have you might not be able to have a disc on the backwhat frame have you got? Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted February 14, 2008 Author Report Share Posted February 14, 2008 depending on what frame you have you might not be able to have a disc on the backwhat frame have you got?i mean front disk lol not rear i cant Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted February 14, 2008 Report Share Posted February 14, 2008 i mean front disk lol not rear i cant ok well you can have a front disc hub and still run a HS33 or a vee Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted February 14, 2008 Author Report Share Posted February 14, 2008 ok well you can have a front disc hub and still run a HS33 or a veeyea i know lol but i dont have rear disk mounts so i cant run disk on rear but when i get viz curved forks then i will be able to run front disk Quote Link to comment Share on other sites More sharing options...
0zzy Posted February 14, 2008 Report Share Posted February 14, 2008 I've never tried anything made by Meta, but I know Viz are good reliable trials products.I'd get the Viz ones, cheaper, and more choice of colour two!amen. Quote Link to comment Share on other sites More sharing options...
