gasgas rider Posted February 14, 2008 Report Share Posted February 14, 2008 hey im running a 22 20 gear, what would i need if i was using a 16 t on front?x Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted February 14, 2008 Report Share Posted February 14, 2008 hey im running a 22 20 gear, what would i need if i was using a 16 t on front?xare you running that on a 20" or 26"?? because the normal gearing for 20" is 18 12 gearing Quote Link to comment Share on other sites More sharing options...
gasgas rider Posted February 14, 2008 Author Report Share Posted February 14, 2008 are you running that on a 20" or 26"?? because the normal gearing for 20" is 18 12 gearing im running it on a 26, but i wna gop mod what would be the eqivalant m8? Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted February 14, 2008 Report Share Posted February 14, 2008 (edited) im running it on a 26, but i wna gop mod what would be the eqivalant m8?OK first download the spell checker and also don't you text talkthen if you wanted to go mod go 18 12. Edited February 14, 2008 by titty boy Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted February 14, 2008 Report Share Posted February 14, 2008 16on the front would be wayyyyyy too small,18-16 is the most common stock ratio!=D Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted February 14, 2008 Report Share Posted February 14, 2008 16on the front would be wayyyyyy too small,18-16 is the most common stock ratio!=Dwhat you mean?? i did not say 16 on front i said 18 on front 12 on back. Quote Link to comment Share on other sites More sharing options...
Ladd Posted February 14, 2008 Report Share Posted February 14, 2008 what you mean?? i did not say 16 on front i said 18 on front 12 on back.18 -12 on stock go for 18-15 Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted February 14, 2008 Report Share Posted February 14, 2008 what you mean?? i did not say 16 on front i said 18 on front 12 on back.hey im running a 22 20 gear, what would i need if i was using a 16 t on front?x Quote Link to comment Share on other sites More sharing options...
Peperami Posted February 14, 2008 Report Share Posted February 14, 2008 Im running 22:17 for stock Quote Link to comment Share on other sites More sharing options...
gasgas rider Posted February 14, 2008 Author Report Share Posted February 14, 2008 what woul dbe the same as 22 20 on stock what would it be for a mod? Quote Link to comment Share on other sites More sharing options...
eskimo Posted February 14, 2008 Report Share Posted February 14, 2008 (edited) hey im running a 22 20 gear, what would i need if i was using a 16 t on front?If you're using 22/20 then 16/14 or 16/13 would be almost the equivalent. 16/14 would be a little harder and 16/14 a little easier. For the mod to keep the same ratio as what your running on the stock i'd say 16/14?That's a guess and i can't find a ratio chart thing.And to be honest i don't really understand what your asking so i hope this is what you were after.[edit] from your post above i was right in thinking that's what you were on about. search for a ratio calculator on the forum. there was one about at some time... Edited February 14, 2008 by eskimo Quote Link to comment Share on other sites More sharing options...
gasgas rider Posted February 14, 2008 Author Report Share Posted February 14, 2008 If you're using 22/20 then 16/14 or 16/13 would be almost the equivalent. 16/14 would be a little harder and 16/14 a little easier. For the mod to keep the same ratio as what your running on the stock i'd say 16/14?That's a guess and i can't find a ratio chart thing.And to be honest i don't really understand what your asking so i hope this is what you were after.[edit] from your post above i was right in thinking that's what you were on about. search for a ratio calculator on the forum. there was one about at some time... thank you very much that was exactly what i was askingthanks u very much take care Quote Link to comment Share on other sites More sharing options...
Ben H! Posted February 14, 2008 Report Share Posted February 14, 2008 i'm currently running 18:12 on my mod which i think is the standard gearing Quote Link to comment Share on other sites More sharing options...
Mike Winton. Posted February 14, 2008 Report Share Posted February 14, 2008 16on the front would be wayyyyyy too small,18-16 is the most common stock ratio!=Dfor fannys it is Quote Link to comment Share on other sites More sharing options...
gasgas rider Posted February 14, 2008 Author Report Share Posted February 14, 2008 i'm currently running 18:12 on my mod which i think is the standard gearingyh tnx m8 but im getting a middleburn cranks super isis which can only have 16 t Quote Link to comment Share on other sites More sharing options...
Scott Norman Posted February 14, 2008 Report Share Posted February 14, 2008 yh tnx m8 but im getting a middleburn cranks super isis which can only have 16 toh ok and stop using text talk Quote Link to comment Share on other sites More sharing options...
Andeee Posted February 14, 2008 Report Share Posted February 14, 2008 Id Advise to 20:18 its what im running Possibly the best stock ratio. Dont do the mod ratio by using a small front such as 16s i find it rather stupid. Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted February 14, 2008 Report Share Posted February 14, 2008 for fannys it is thought he meant for stock :$ Quote Link to comment Share on other sites More sharing options...
gasgas rider Posted February 14, 2008 Author Report Share Posted February 14, 2008 thought he meant for stock :$ sorry about that mate, i messed up the postx Quote Link to comment Share on other sites More sharing options...
