Milford Cubicle Posted February 14, 2008 Report Share Posted February 14, 2008 Hi i was wondering i have just stripped one of the threads in my frame for my maggie. I was wondering if i drilled a hole in the other side of my frame and ran a longer bolt and then did it up with a nut on the other side, A-would it hold it properly? andB-would it weaken my frame at all?Thanks in advancebillxxx Quote Link to comment Share on other sites More sharing options...
Al_Fel Posted February 14, 2008 Report Share Posted February 14, 2008 You don't want to be drilling holes through your frame. What you need my friend is a heli coil. Basically your drill the hole out to the size up and inscert a steel thread which brings it back to the right size. Quote Link to comment Share on other sites More sharing options...
Tony Harrison Posted February 14, 2008 Report Share Posted February 14, 2008 What is it with people hanging off 4/5mm allen keys like this? I've never stripped a Maggie thread, ever! Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted February 14, 2008 Report Share Posted February 14, 2008 run a bolt from the bottom up and secure the nut at the top. it'll be easier to get it set up that way. Quote Link to comment Share on other sites More sharing options...
monty221pr Posted February 14, 2008 Report Share Posted February 14, 2008 Heli coils are the best answer for this problem, My frame is currently heli coiled and its fine. If they are not really bad a ghetto way is to wrap tape around the bolt, a really thin layer, this seem to help threas hold but their is a minimal chance of this actually working. I suppose its best to try a few things before you go all out and drill your frame. Quote Link to comment Share on other sites More sharing options...
cai Posted February 14, 2008 Report Share Posted February 14, 2008 Helicoil!Because helicoils are made of steel, they are actually stronger than the original threads in your magura mounts.Your local bike shop should be able to do it for relitively cheap! (or an engineers should be able to do it). Quote Link to comment Share on other sites More sharing options...
0zzy Posted February 14, 2008 Report Share Posted February 14, 2008 helicoil, these are much stronger then normal threads, some people get brand new frames and just wack these in because of the better strength. Quote Link to comment Share on other sites More sharing options...
BIG Drew Posted February 14, 2008 Report Share Posted February 14, 2008 Neil T did exactly what you said on his A1 and that held out. Was a right pain to set up though. Helicoiling would be your best bet. Quote Link to comment Share on other sites More sharing options...
basher Posted February 15, 2008 Report Share Posted February 15, 2008 Use search theres a few threads like this, helicoil is what you want to do. Quote Link to comment Share on other sites More sharing options...
Milford Cubicle Posted February 16, 2008 Author Report Share Posted February 16, 2008 Thanks for the replies but the reason i was trying to find an alternetive to a helicoil is because i have no monies and also dont know were to get it done.billxxx Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted February 16, 2008 Report Share Posted February 16, 2008 Theres only a few alternatives to helicoiling, and they don't give you the original benefits of yoyr standard 4 bolt mount.For example putting a longer bolt with a nut on the end would mean drilling a hole in the frame when it could be avoided, and tapping the thread the next size up means a bigger bolt which will mean you will have to make space in your clamps and booster.One other idea I was going to try before I went for helicoiling was to get someone to weld the hole, and re tap the thread.But Helicoiling is much stronger and easier.If you want your problem sorted you will have to spend a bit of money and do a bit of searching.I got 2 of my 4 bolt holes helicoiled by a bloke who does motorbike tuning, and that only cost me £5.Have a look in your Yellow pages for an engineer or a local firm that works with car repairs/engines, as they either do it themselves or will know someone who can do it for you. Quote Link to comment Share on other sites More sharing options...
