A Very Warn Grind
Ben John-Hynes
I have the same grind as you do (was sharp and light by Tarty, now its basicly smooth) and I run Magura Brown pads, the sound & bite is okay, but hold is amazing!
I'm going to purchase a grinder soon though, and perhaps some Rock Blues!
Basically Deng pads on a deng rim will work well. Mostly due to the style of the grind and the testing which was carried out but deng.
Same with Try-all Pads, they work best on Try-all rims.
Basically the pad has been designed to work to the best of its ability on one type of rim, its own brand.
If you run echo rims I would say yes to these pads. Otherwise try-all greens are very good on try-all rims and softer compound rims.
Nathan
Edited by Koxx_Nath.C
If you run echo rims I would say yes to these pads. Otherwise try-all greens are very good on try-all rimsand softer compound rims.
Nathan
abig help.
as use try-all rim!
:D
cheers everyone!
