Sir_Hops_Alot Posted February 13, 2008 Report Share Posted February 13, 2008 (edited) Is there any other way to remove your cranks without damaging them, if you don't have a tool? Edited February 13, 2008 by Sir_Hops_Alot Quote Link to comment Share on other sites More sharing options...
Joe Papasnap Maher Posted February 13, 2008 Report Share Posted February 13, 2008 http://www.tartybikes.co.uk/product.php?id=559 Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted February 13, 2008 Author Report Share Posted February 13, 2008 Yeah cheers Joe but my cranks are not isis. Quote Link to comment Share on other sites More sharing options...
basher Posted February 13, 2008 Report Share Posted February 13, 2008 quick tap with a rubber mallet Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted February 13, 2008 Author Report Share Posted February 13, 2008 quick tap with a rubber malletThanks mate. Quote Link to comment Share on other sites More sharing options...
Greetings Posted February 13, 2008 Report Share Posted February 13, 2008 Undo the bolts and ride around. The cranks will drop off. Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted February 14, 2008 Author Report Share Posted February 14, 2008 Undo the bolts and ride around. The cranks will drop off.Won't it also damage them? Quote Link to comment Share on other sites More sharing options...
Greetings Posted February 14, 2008 Report Share Posted February 14, 2008 Won't it also damage them?Theoretically yes, practically - i don't know. You'll notice when they get loose though, so don't worry about hurting yourself. Quote Link to comment Share on other sites More sharing options...
Phil H Posted February 14, 2008 Report Share Posted February 14, 2008 Heat them up mega style and then hit them with a hammer or mallet.Phil Quote Link to comment Share on other sites More sharing options...
yoyoyo Posted February 14, 2008 Report Share Posted February 14, 2008 http://www.tartybikes.co.uk/product.php?id=559- 'Plug' attached to the end of the tool allows ISIS cranks to be easily removed. However, if you have square taper cranks just remove the plug and it will also work perfectly. Quote Link to comment Share on other sites More sharing options...
BenLeacockâ„¢ Posted February 14, 2008 Report Share Posted February 14, 2008 If there the onza cranks you could most proberly pull them off with your hands? I managed to get a set of a t-bird! Quote Link to comment Share on other sites More sharing options...
Muel Posted February 14, 2008 Report Share Posted February 14, 2008 Just buy a tool, they hardly cost anything. Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted February 14, 2008 Report Share Posted February 14, 2008 definitely invest...seriously handy tool to have! Quote Link to comment Share on other sites More sharing options...
Sir_Hops_Alot Posted February 14, 2008 Author Report Share Posted February 14, 2008 Yeah but i'll be seriously skint when i buy them, alos will my standard onza bash ring fit onto echo forged cranks? Quote Link to comment Share on other sites More sharing options...
