Casula Posted February 12, 2008 Report Share Posted February 12, 2008 hi i bought some try all forks and now my mounts that i have for the maguras to hold on to the forks are to far away from the wheel i cant push the pots in any closer or anything would this mean i need to blead my brakes or something else has anyone got any ideas thanks guys let me know as im bike less !!!!! Quote Link to comment Share on other sites More sharing options...
0zzy Posted February 12, 2008 Report Share Posted February 12, 2008 use some tensile offset mounts and turn them around, also give it a rebleed for maximum performance. Quote Link to comment Share on other sites More sharing options...
Skoze Posted February 12, 2008 Report Share Posted February 12, 2008 Have you puit the calipers all the way in? Is there much life left in the pads? HAve you done the tpa?If you have, tensile offset mounts. Quote Link to comment Share on other sites More sharing options...
Paul@Deltabikes Posted February 12, 2008 Report Share Posted February 12, 2008 The above comments are correct. Also if you are running a very skinny rim you may want to look into changing it for something with a wider profile.Paul Quote Link to comment Share on other sites More sharing options...
DANNI BOI Posted February 12, 2008 Report Share Posted February 12, 2008 like i said mate offset mounts r the 1s 4 u!and i no that a new set of pads would helpALOTlol Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted February 12, 2008 Report Share Posted February 12, 2008 The above comments are correct. Also if you are running a very skinny rim you may want to look into changing it for something with a wider profile.Paulthat would solve your problemwhat rim you got? Quote Link to comment Share on other sites More sharing options...
Casula Posted February 12, 2008 Author Report Share Posted February 12, 2008 cheers i think ill but the tensile offset mounts thanks everyone Quote Link to comment Share on other sites More sharing options...
nicks Posted March 25, 2008 Report Share Posted March 25, 2008 cheers i think ill but the tensile offset mounts thanks everyone Quote Link to comment Share on other sites More sharing options...
