Snaped Forks
TrAsHeR
Was riding then I did like a little hop forward but I Didnt make it high enough so my front wheel taped the stair in front quiet hard I heard a small crack checked but couldn't see anything. So carried on riding as normal then stoped and but my front brake no and pushed the back forward. And It snapped like a peace of cheese. :(
Any onne can tell me if th heaset is alright or broken ?
Heres the pics
So iam now riding my echo but I cant stand magura.
A quick queston the piston on the magura slave wont come back in all the way what should I do ?
Edited by TrAsHeR
normally, you have at the top - a rubber ring to hold it together, the outer shell bit, the bearings, which if sealed, should not be loose, then the cup in the frame, and in the bottom - a cup, another set of bearings, then sometimes a plastic ring, some form of race, and then the flange on the forks
if you've got anything that's not a complete ring, its broke. If your bearings are loose and they should be sealed, its broke. otherwise, its just come apart
