Frames
Ben H!
i like bikes with small wb's and no mate i am not mad of pure money it will be a on-going thing if i do decide to build it, it should be finished by december i am planning on the orange dual disc with white rims but the frame will be very much protected can't wait to see what it will looks like
Edited by Czartrials
so you've just got a new echo lite 08 disc, and you already want a new frame?
whats wrong with you? >.>
EDIT: Your wrong, it's a different user, you are getting confused between the names czarbikes and czartrials. I believe an apology is in order.
Phil
Edited by Phil H
no its not hydroxx is 990 >_<
didn't realise that the thing is i want a really short bike and something that is shorter than my 221 ti i heard the shorter the wheelbase the easier it is to get up on the back tyre but i am only 5ft
2 i thought i shorter bike would help me learn more
No-one has owned one yet, and the WB is very, very small short.
I believe someone in Jersey owns the older model.
They look pretty damn sweet, if I knew of anybody who had tested it fully I would have gone for one.
But the maker has done a Deng, the old version had both mounts, not two frame options.
Since I went back to a long frame, taps and ups have been much, much easier and I am now able to really push the height I can do.
If you struggling to hop up to the back wheel, you can do two things:
1. Practice more, I know this has been said all the time, but I never used to be able to do it on slanted things, now I'm starting to get strong enough to do it.
2. Lower the gear ratio, I'd put a 13t sprocket on the rear if I were you to make it easier.
If you really are only 5ft tall, then you would benefit from a really short frame, my brother is 5'4" and he rides a T-Lite (985mm), which suits him right down to the ground.
I did have a short Echo, but I'm 5'10" so it's a bit restrictive, the 08 Echo Lite is 1020 so it feels like a short bike should to me.
thanks for the advice i will really think about it but i think the dob frame i am going to go for because the echo lite short is the same wb as my monty ti and i want something a bit shorter i need to ask you something else actually what colour hub would you have with a white rim that looks the best cheers
I'd say white hubs, white rims, that's what I have and I love it. I think any coloured hub other than black or white look pants.
If you getting the Dob, get the orange one with white wheels, or the white frame with white/black hubs and some nice fluro Try-All rims.
cheers muel you're a really good guy and i am really thank full for all you're help i was planning of the orange frame, with white rims which hub though the viz or the 221 ti but i am still going with white and the dob white magnesium rims
Get the viz hub, I have the 221TI, and although it is a very good, light, strong hub, it's a b*****d to set up because it's designed for the snail cams to go on the outside of the frame, so the disc rotor ends up to far away, so I have got about 4/5mm of spacers between the caliper and the frame.
And me MSN if you want dude, I'm off now but I'll be on later.
el_muelio@hotmail.co.uk
might be on later but if not i will be out i have added you though
