Wots The Difference
squeaky
hi there i was looking on tartybikes today and i was after getting a new rim brake i had a look at the normal maguras and then i saw the echo cnc brake and i was wanting to know why it costs so much money. what is the difference between them aswell.
ones CNC'ed, the other cast. it costs more because it has to be machine CNC'ed, out of a block of aluminuim.
the main difference is the feel, the echo feels stiffer and more responsive, but it leaks like a bitch aswell.
Edited by El Cristoff
its all cnc'd...and also you get better quality pads clamps and lever blade there not that much when you compare it to a magura
Magura £65 standard pads and clamps..Later you might get decent pads £18 then a blade £25 then clamps £25 so thats £133
The Echo brake is of similar value since you get loads of extras with it, but you'll be better off with a Magura. I've come across and sold lots of these brakes, and roughly 90% of them leaked. And the main problem is that once you get used to it, I find it's really difficult to go back to a Maggie.
