lloyd GU Posted February 4, 2008 Report Share Posted February 4, 2008 hello people .. im getting some zoo forks 26" .. but i ant had thm befor and i was wondering if you could help me out and tell me how good they are .. ? thanks lloyd ... Quote Link to comment Share on other sites More sharing options...
mata22 Posted February 4, 2008 Report Share Posted February 4, 2008 (edited) i have them on my pitbull, i think they are great, if i had to buy another for it would be zoo again Edited February 4, 2008 by mata22 Quote Link to comment Share on other sites More sharing options...
squeaky Posted February 4, 2008 Report Share Posted February 4, 2008 well all the people that i know with them say that they are good and worth all of the money that they paid for them Quote Link to comment Share on other sites More sharing options...
steve@banbury-trials Posted February 4, 2008 Report Share Posted February 4, 2008 as far as i know they are one of the strongest trials fork availiable,havent used them so i cant review them really.steve Quote Link to comment Share on other sites More sharing options...
Adrian J Posted February 4, 2008 Report Share Posted February 4, 2008 They are a hell of alot stiffer than the echo urbans and echo lites so if you use a disc i would go for the zoo forks...the only real benefit with the urbans or the lites is you can have a disc mount and backwards four bolt mounts on the same fork rather than limiting yourself to 1 particular brake setup. i had the 26" zoo forks on my pitbull however i didnt like my disc brake after a while of using it so went back to urbans with front magura.Adrian j x Quote Link to comment Share on other sites More sharing options...
brick_top Posted February 4, 2008 Report Share Posted February 4, 2008 Zoo! forks are pretty heavy but it lasts forever. I broke an "old version" Zoo! fork and went for "new version" one. Works well for me. Quote Link to comment Share on other sites More sharing options...
basher Posted February 4, 2008 Report Share Posted February 4, 2008 If your on about stock get viz forks if you can aford them. Quote Link to comment Share on other sites More sharing options...
Muel Posted February 4, 2008 Report Share Posted February 4, 2008 (edited) They are a hell of alot stiffer than the echo urbans and echo lites so if you use a disc i would go for the zoo forks...the only real benefit with the urbans or the lites is you can have a disc mount and backwards four bolt mounts on the same fork rather than limiting yourself to 1 particular brake setup. i had the 26" zoo forks on my pitbull however i didnt like my disc brake after a while of using it so went back to urbans with front magura.Adrian j xThey are also lighter, cheaper and look nicer in my opinion.I only like black forks though, maybe it's just me being wierd. Edited February 4, 2008 by El Muelio Quote Link to comment Share on other sites More sharing options...
Adrian J Posted February 4, 2008 Report Share Posted February 4, 2008 (edited) They are also lighter, cheaper and look nicer in my opinion.I only like black forks though, maybe it's just me being wierd.true, nice and simple design.... Edited February 4, 2008 by Adrian J Quote Link to comment Share on other sites More sharing options...
jacecottrials Posted February 4, 2008 Report Share Posted February 4, 2008 They are stronger than urbans but i thought this made them more brittle?? As in they dont crack they just snapp? Though i think u need to weigh a fair amount to snap them, i may be wrong? Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted February 4, 2008 Report Share Posted February 4, 2008 Can't fault mine in the slightest, solid as you like from what I've given themTempted to get a set of Urbans now they're available in black though - due to them being a little lighter (I'm not that harsh, at least, I don't think so!) Quote Link to comment Share on other sites More sharing options...
Tom_ Posted February 4, 2008 Report Share Posted February 4, 2008 If your on about stock get viz forks if you can aford them.dont.urbans if your running a rim brake, or zoos for disk Quote Link to comment Share on other sites More sharing options...
basher Posted February 4, 2008 Report Share Posted February 4, 2008 dont.urbans if your running a rim brake, or zoos for disk Viz are pritty dam strong forks. The steerer join is alot stronger than deng forks. Quote Link to comment Share on other sites More sharing options...
