Removing Anodizing
Josh PWND
You can use oven cleaner instead as caustic soda as oven cleaner has just enough caustic init to remove the anodizing leaves a horrible finish but if your re painting it doesnt matter.
Pros
Safer than caustic soda
easier to get hold off
Cons
Takes 45 minutes
Horrible finish
Pros
Cons
Takes 45 minutes
Horrible finish
Ok and theres sand blasting? loads of stuff, i ask you why post this? maybe as a wiki not in chit-chat :S
