Juicy 7 Vs. Code
spartan
Ok so I'm in the market for a new front disc brake. A lot of people have suggested the bb7 but i have had several bad experiences with them in the past. I also prefer the feeling of a hydraulic brake.
So I am trying to decide which brake is better. Price is not an object because i get big discounts on avid products so it is more and issue of weight, power modulation. The Juicys i have felt in the past feel really good but im not sure whether they have as much power or modulation as the code.
And seeing as the code is only 50 grame heavier it seems like a better deal.
Also, what is the difference between the Juicy 7 and the Juicy ultimate??.
Thanks for the help guys,
Ian
a juicy ultimate has carbonfibre lever and verious titanium and aloy parts making it lighter , also keep in mind that the code diskbrake was designed as a freeride brake witch will have more modulation . if i was you i would get the juicy seven but your probbaly going to get bombarded by people saying buy a hope (N)
i run a juicy 7 on my bike and when you want it to bite it dose just that its great for it....
when you get used to it then stoppies and gaps to front are ok...
but when other people get on it just warn them as they are sharpe
x
