Ste Wilson Posted January 30, 2008 Report Share Posted January 30, 2008 Wanting to spray my frame white.. I have an echo team 07 just wondering what type of paints i need to use and if i needed primer and how many coats etc...Also do i have to sand the frame down with wet and dry sand paper?Couple of my mater said hammerite but... All comments welcome ste Quote Link to comment Share on other sites More sharing options...
BenLeacock™ Posted January 30, 2008 Report Share Posted January 30, 2008 Pritty sure this will help ? Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted January 30, 2008 Report Share Posted January 30, 2008 it all depends how you want to spray it, compressor and airgun or can then you need to think about colour and type of paint matt is easier as you don't have to do as much prep shiney black is probs the hardest you will need primer halfords scratch filling primer than a few coats of normal works the best you'll need to do a few coats of paint just make sure you've got a good even covering and clear laquer afterwards should help prevent it scratching so easily for the prep you'll need give the frame a good rub down with any sandpaper (not too harsh) lust to take the shine off of the old laquer and if you have any dents/deep scratches you can use car bodywork filler to fill them Quote Link to comment Share on other sites More sharing options...
TrAsHeR Posted January 30, 2008 Report Share Posted January 30, 2008 Pritty sure this will help ? Yeah follow that but really when you spray do lots of small coats Quote Link to comment Share on other sites More sharing options...
Broomer Posted January 30, 2008 Report Share Posted January 30, 2008 (edited) it all depends how you want to spray it, compressor and airgun or can then you need to think about colour and type of paint matt is easier as you don't have to do as much prep shiney black is probs the hardest you will need primer halfords scratch filling primer than a few coats of normal works the best you'll need to do a few coats of paint just make sure you've got a good even covering and clear laquer afterwards should help prevent it scratching so easily for the prep you'll need give the frame a good rub down with any sandpaper (not too harsh) lust to take the shine off of the old laquer and if you have any dents/deep scratches you can use car bodywork filler to fill themI would not bother, as soon as you knock it again it will just all fall off. Edited January 30, 2008 by Broomer Quote Link to comment Share on other sites More sharing options...
NileBrown™ Posted January 30, 2008 Report Share Posted January 30, 2008 And don't listen to your mates when they say use hammerite. Its honestly shit when it comes to frames. Quote Link to comment Share on other sites More sharing options...
Ste Wilson Posted January 30, 2008 Author Report Share Posted January 30, 2008 And don't listen to your mates when they say use hammerite. Its honestly shit when it comes to frames.thanks should i just use halfords cans? Quote Link to comment Share on other sites More sharing options...
Lock-N-Load Posted January 31, 2008 Report Share Posted January 31, 2008 (edited) And don't listen to your mates when they say use hammerite. Its honestly shit when it comes to frames.Isn't hammerite for steel not aluminium anyway? Edited January 31, 2008 by Lock-N-Load Quote Link to comment Share on other sites More sharing options...
