Josh PWND Posted January 29, 2008 Report Share Posted January 29, 2008 i just water bled my brakes perfectly but the pistons on the slaves dont move atall please help Quote Link to comment Share on other sites More sharing options...
NileBrown™ Posted January 29, 2008 Report Share Posted January 29, 2008 If its done perfect then it would be fine hahaare you bleeding the brake with the tpa off? that helps also what method are you using? bucket, syringes? Quote Link to comment Share on other sites More sharing options...
Josh PWND Posted January 29, 2008 Author Report Share Posted January 29, 2008 i have a broken 05 tpa so it pretty much always off and im doing a bath bleed Quote Link to comment Share on other sites More sharing options...
Simpson Posted January 29, 2008 Report Share Posted January 29, 2008 I would put money on it that your just really not bleeding your brake properly, get someone else to try to do it, if the levers pulling and the cyclinders arn't moving then the brake CANNOT be bled properly, because its a closed system, if the system has no holes in it or anything then the water must go somewhere.... its hard to say much more than that online, but im sure a raped tpa isnt helping things Quote Link to comment Share on other sites More sharing options...
Josh PWND Posted January 29, 2008 Author Report Share Posted January 29, 2008 right just tried again and i pull it in and it moves a tiny bit but im bleeding it right as i have done it loads of times succesfully Quote Link to comment Share on other sites More sharing options...
Josh PWND Posted January 29, 2008 Author Report Share Posted January 29, 2008 know it worked but i got 1 lazy slaveand i lubed them alll up Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 29, 2008 Report Share Posted January 29, 2008 (edited) use the fixing a lazy piston method: here Edited January 29, 2008 by Disasterboy Quote Link to comment Share on other sites More sharing options...
