Gandalf the Yellow Posted January 29, 2008 Report Share Posted January 29, 2008 (edited) right, i have a DOB 08 with 116mm dropout, and i want to run a monty hub on it (white is damn pimping)-(i believe its 106mm for monty frames)on trials-uk.co.uk dan says its also compatible with 110mm, but the question is will it work with the DOB frame with snail cams??sorry for being a retard, but help would be nicesteve EDIT:got another question really. i have a SKF bb and its pretty much brand new, they're lush and don't really want to get another bb for the DOB, i've got tryall isis cranks and symmetrik bashring planning to go on the new bike, and with the monty hub i will need to run freewheel. what is the best way to do this? obviously getting an ENO, but it may not work with the SKF as a ffw right?does it mean i can run the FW on the back and have a tiny fixed cog on the cranks instead?cheers Edited January 29, 2008 by StinkEE Quote Link to comment Share on other sites More sharing options...
ZeroMatt Posted January 29, 2008 Report Share Posted January 29, 2008 Well I don't know from experience but from those figures I'd say yes. The snail cams act as spacers and I think some are wider than others. Maybe just the monty ones are thinner? Quote Link to comment Share on other sites More sharing options...
Simpson Posted January 29, 2008 Report Share Posted January 29, 2008 Have a look on Biketrialstation.com The blokes speak great English and quoted me under 125quid for a DOB frame including insured postage, could save you a BOMB man. Quote Link to comment Share on other sites More sharing options...
basher Posted January 29, 2008 Report Share Posted January 29, 2008 (edited) Dont quite me. But hubs are 110mm spaceing and the snail cams make it up to 116mm spacings which frames are. So the monty hub (106mm) will work but you will probs have to use a washer on both sides. Edited January 29, 2008 by basher Quote Link to comment Share on other sites More sharing options...
Gandalf the Yellow Posted January 29, 2008 Author Report Share Posted January 29, 2008 Have a look on Biketrialstation.com The blokes speak great English and quoted me under 125quid for a DOB frame including insured postage, could save you a BOMB man.thats where i got it from cheers though.anyway. you really think a washer on either side will work?steve Quote Link to comment Share on other sites More sharing options...
basher Posted January 29, 2008 Report Share Posted January 29, 2008 thats where i got it from cheers though.anyway. you really think a washer on either side will work?steveyeah should be fine if your using a maggie and not a disk and if you are you can just fiddle with the washers to get the disk right. Quote Link to comment Share on other sites More sharing options...
TrAsHeR Posted January 29, 2008 Report Share Posted January 29, 2008 Sorry my reply isnt really in the theme of your topicBut have you got a 20 dob frame if so how does it ride ? Is it flexy ? And do you run it double disk ?Cheers Quote Link to comment Share on other sites More sharing options...
Tomy P Posted January 29, 2008 Report Share Posted January 29, 2008 Could you explain the how you got one off that site? Thanks, tom Quote Link to comment Share on other sites More sharing options...
Gandalf the Yellow Posted January 29, 2008 Author Report Share Posted January 29, 2008 Sorry my reply isnt really in the theme of your topicBut have you got a 20 dob frame if so how does it ride ? Is it flexy ? And do you run it double disk ?Cheersna its the 26 mate and haven't got it just yet, will be with me in a week or 2.Could you explain the how you got one off that site? Thanks, tomneed to email or ring them, just make sure you're ringing them at the right time its 7 or 8 hours time difference.and i got connections so i just bought it from the shop.anymore people have ideas??steve Quote Link to comment Share on other sites More sharing options...
JoeM Posted January 29, 2008 Report Share Posted January 29, 2008 It should be fine, I have to run spacers and chain tugs on my zoo with a monty hub. Although watch the chainline otherwise you might have the chain start to rub on the frame. Quote Link to comment Share on other sites More sharing options...
