Bike Weight
adamof
Hello people, I`ve been around for some time, just browsing the forum and I've decided to post a thread myself : )
So here`s the catch. What bike do you have and what`s it's weight preferably in kilograms as I'm from the mainland of Europe: )
He I go:
Adamant A2 - 12kg ; ) looks bit heavy though : \
where do you weigh them?
my bike doesn't seem to fit on my bathroom scales?!
>_<
llol
Haha, Well. When i worked in cycleworks i baught a meathook type weight measurer, You just hang th bike off it and it weighs it (Y)
got a String on the top too so you can hang it anywhere...
http://www.chainreactioncycles.com/Models.aspx?ModelID=12979
Jarrod
Pashley 26 - 16Lbs wich equates to about 6.8Kg's
Jarrod
i want photos and a spec list, i would be incredibly surprised if it actually did weigh that little.
fair shouts if it does..... but im a little spceptical when you consider most pro comp trials bikes dont weigh that little.
my bionic 10.5 kilos/23lbs measured in the same way with a meat hook scale at the bikeshop.
Edited by craigjames
It is.......7.2kgs ! I tried to convert it in my head ! haha :(
Jarrod
As said, it's 16lbs wich is actually 7.2/5 kgs but it's still pretty light (Y)
Xtr External BB
Hone single speed chainset
Gusset Single Speed kit with a Drilled Surley chainring
Dura ace Rear mech
Mavic Crossland front wheel
Hope Hub'd Mavic rear wheel
Truvativ Team stem
Monkey light CNT Downhill bars (off my Orange)
Sram PC991 Chain
Those stupid Maxxis Lightweight tubes that pop above 20psi...
Fatty Forks
Pashley frame
Sdg Bel air seat
Hope Headset
V12 Mags
Think thats about it ? The Photo dosen't show it with a few of the other light bits off my Orange, Like the Front Disc brake and Carbon Bars....
My orange wasn't much heavier....Being an SL and all
*Awaits the Onslaught of abuse*
And before you start the "You probably measured it wrong" I was a cycle mechanic for 7 years (Y)
Jarrod
Edited by Pashley26
still cant beleive its that light, seems crazy. my pashley was 25lbs/11.3kilos
ghz frame, pashley forks
maggy's front and rear
heatsink booster
middleburn cranks
skf bb
pro2 on mavix dx32 rim rear
hope xc on d521 front
maxxis single ply 2.3 highrollers
viz bars
pazzaz stem
my bionic:
bionic frame
echo control forks
dmr revolver on a onza hog drilled rim
wtb laser disc lite on a dx32
avid bb7's front and rear
avid sd5 levers
hope stem
CK headset
onza carbon bars
middleburn cranks
skf bfr 300 bb
wtb skinny front tyre folding jobby
maxxis 2.35 dual ply st highroller rear
tensile freewheel
wellgo mg1 pedals
raleigh lite tubes
nc 17 chiant tensioner
sram pc990 chain
so a little different from the pic
16lbs isnt quite light, its stupidly light, thats why i queried it.
how can i make my bike lighter its an onza t-pro o6ish maggies f+b viz hub on try-all rim. zoo! riser bar (the new ones) echo team stem, echo lite forks, dmr v8 pedals, echo tyres soon to be changing to some maxis c-c to save a bit of weight and actually get some grip :P im nitromorssing the frame as soon as it brakes next as i cba to take it apart when its working fine. sooo any ideas? ??
cheers ozzy, (sorry for hi-jacking thread btw)
Does wait really make that much difference? Seems to me that these days people are doing ridiculous and expensive things to shave of a few grams which would lose the equivelant to having a shite before riding.
i will second that....or spend the time and money down the gym to get bigger muscles so yuo can lift the bike higher....
