Converting A 26" Frame For 24" Wheels?
Big_oll
Hi guys,
i've got a revell and was wandering what it would ride like if i welded some new brake mounts on it so it would take a 24" wheel? Would it ride like a shed?
How different is the geometry between 24" frames and 26" ones?
If anyone has any idea or has done it, let me know!
oliver
Edited by Big_oll
Hi guys,
oliver
you would probably find the bottom bracket quite low....and it might look a bit wierd :S
the bb height wont actually change in comparison to the axels, the +30 on a zoot is the same as the +30 on a stock just as its an inch lower its the eqivilent of +10ish on a stock.
What is the geo on the revel frame?
I remember Phil Feeney had a 26" curtis frame converted although it was at the time of being built. I think all that was done was the brake bosses were moved down to accommodate a rim brake on the back. The geometry stayed the same (correct me if I'm wrong) but the bike clearly rode ok as you can tell from his level of riding :)
i would only recommend if you are a good welder as it could weaken the frame plus you want the brake mounts to be firmly in place lol
its a steel frame so wont be too much of an issue. i cant remember what the bb rise on a revell is but if its +20 then i should be ok. backend will be very long though
Its your welding skills i'd worry about!
haha, i can weld, there won't be a problem there.
Would the chainstays be weirdly long???
I might just make an adjuster bracket with a built in booster type arrangement...hmmmm....
weird topic to bring it up in but check out the booster i made,
Sooo, has anyone done it apart from the guy mentioned earlier???
oliver
Ive ridden 24's on 26 frames....but like f**k Id weld new brake bosses on :o
Im not doubting your welding, but you know how thin chainstays are? Your gonna have to be mega careful you don't blow a hole in them. And imagine if it not perfect and you get a load of pigeon shit.....and it lets go ontop of a 10ft drop. I think poo would come out and teeth might snap off.
I know it looks a bit wank, but when I used to ride BMX, if the rear didnt have V mounts, you'd cut the chainstays off a MTB frame so you have the mounts and brace and jubilee clip it to the back end. job done.
