matt middler Posted January 28, 2008 Report Share Posted January 28, 2008 I have just bought a Czar ivan frame, the 05/06 model in short. Im going to be using square taper cranks so need some help on what BB to get.Needs to have 68mm shell, But I could do with some suggestions to what axle length to get, and also what Brand/model.I always used to use a Shimano UN53 i think it was. Quote Link to comment Share on other sites More sharing options...
Andeee Posted January 28, 2008 Report Share Posted January 28, 2008 It depends what cranks your running. i.e. clearance between the crank arms and chain stay. Off the top of my head most deng frames tend to take a 127.5mm b/b or even a 128mm depending on what cranks you've got. Quote Link to comment Share on other sites More sharing options...
matt middler Posted January 28, 2008 Author Report Share Posted January 28, 2008 Middleburn RS7's Quote Link to comment Share on other sites More sharing options...
psycholist Posted January 28, 2008 Report Share Posted January 28, 2008 If you're reasonably light and smooth the UN-72 should last approximately forever. If you're heavy and have regular 'not very smooth' days like me they snap in under a year (And because the axle is hardened steel, when they go they go suddenly and without warning). The longer the BB axle the more likely it is to fail all other things being equal - trials frames tend to need pretty long square taper BB's though, so 127-128mm sounds about right without me knowing about the specific frame... Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted January 28, 2008 Report Share Posted January 28, 2008 127.5 is the norm for most deng frames Quote Link to comment Share on other sites More sharing options...
JonMack Posted January 28, 2008 Report Share Posted January 28, 2008 I'd say a 127.5 just to be on the safe side. A UN-54? is probably a good bet, although a UN-72 would be good too. Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 28, 2008 Report Share Posted January 28, 2008 127.5 should be fine shimano un73 will last you for ever Quote Link to comment Share on other sites More sharing options...
