Jolfa Posted January 27, 2008 Report Share Posted January 27, 2008 I bought some old Raceface Turbine LP's a few weeks ago, then a Filthy ard guard a few weeks later, asuming the rockring would just fit, but the spider on the cranks is much too big/rockring too smallDo these cranks come in some sort a compact setup or what? How can the rockring be too small?!Forgive my daftness :$ Ta! Quote Link to comment Share on other sites More sharing options...
Endohopper Posted January 28, 2008 Report Share Posted January 28, 2008 These cranks appear to have a 110 mm B.C.D ( bolt circle diameter ) , a useful way of ensuring that customers purchase purchase the same brand's accesories . Race Face do make bashguards , but it'd be a shame to leave the 'ard guard unused . How about the chainring itself - does that fit O.K ? Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted January 28, 2008 Report Share Posted January 28, 2008 Its 5 arm right? I guess its that the ard guard is made for compact drive cranks, which most (modern) 5 arms are, and i guess the raceface's you've got are a bit old school and are not compact drive. You could either get compact drive cranks or a big arse bashguard designed for non compact drive, but it will be along the lines of the size of a 4 arm 22t bashguard...so quite big. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted January 28, 2008 Report Share Posted January 28, 2008 Matthew62 said: Its 5 arm right? I guess its that the ard guard is made for compact drive cranks, which most (modern) 5 arms are, and i guess the raceface's you've got are a bit old school and are not compact drive. You could either get compact drive cranks or a big arse bashguard designed for non compact drive, but it will be along the lines of the size of a 4 arm 22t bashguard...so quite big.Thats exactly right...the older cranks had a far larger BCD , so had to be run with a larger bashring (normally around a 32t bashring diameter Quote Link to comment Share on other sites More sharing options...
Jolfa Posted January 28, 2008 Author Report Share Posted January 28, 2008 Endohopper said: These cranks appear to have a 110 mm B.C.D ( bolt circle diameter ) , a useful way of ensuring that customers purchase purchase the same brand's accesories . Race Face do make bashguards , but it'd be a shame to leave the 'ard guard unused . How about the chainring itself - does that fit O.K ?B..But, it's exactly the same cranks and bash Hawziee always used back in'th daySo the Turbine LP's are available in compact?If 110bcd is jumbo, whats compact? Quote Link to comment Share on other sites More sharing options...
psycholist Posted January 28, 2008 Report Share Posted January 28, 2008 Compact for 5 arm is 110mm (130mm is non compact). For 4 arm this is 104mm.http://en.wikipedia.org/wiki/Crankset - have a look under the BCD heading or follow the sheldonbrown link at the bottom of the page for more information than you could possibly ask for on the subject... Quote Link to comment Share on other sites More sharing options...
Jolfa Posted January 28, 2008 Author Report Share Posted January 28, 2008 Smashing, cheoz The eBay listing says they're 110 BCD... Now I'm confused Why won't my bash fit/how did Mr Hawyes have the very same bash on the very same cranks?! Quote Link to comment Share on other sites More sharing options...
Jolfa Posted January 28, 2008 Author Report Share Posted January 28, 2008 (edited) Ok having had a bit of a measure... I need 94BCD cranks to use the 'ard guard.. Bugger.110 is standard, 94 is compact Edited January 28, 2008 by Jolfa Quote Link to comment Share on other sites More sharing options...
