dirt jumper jake Posted January 26, 2008 Report Share Posted January 26, 2008 Hi guyswhy is it that trials bikes have a 20x2.5 on the rear and 20x2.0 on the front why not 20x2.5 front and rear? Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 26, 2008 Report Share Posted January 26, 2008 (edited) saves weight on the front. For a lot of trials moves, the front wheel is in the air, so it's not necessary to have a big-ass tyre.you also need a bigger one on the back for grip Edited January 26, 2008 by Disasterboy Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 26, 2008 Report Share Posted January 26, 2008 Less weight on front and dont need alot of grip on front..just have the tyres lower pressure......Rear has a wider one keeps you abit more balanced and grips more also you run them at low pressure Quote Link to comment Share on other sites More sharing options...
Razz T Posted January 26, 2008 Report Share Posted January 26, 2008 I would use Maxxis Creepy Crawlers. Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 26, 2008 Report Share Posted January 26, 2008 I have used :Onza Sticky fingerTry-allMaxxis creepy crawlersEcho TyresOld monty And now i have chose echo rear and monty front they grip very very well Quote Link to comment Share on other sites More sharing options...
0zzy Posted January 26, 2008 Report Share Posted January 26, 2008 I would use Maxxis Creepy Crawlers. he didnt ask what tyres to use, and its because its wider for more surface area which improves grip, and easier to balance on. Quote Link to comment Share on other sites More sharing options...
