Pashley26 Posted January 26, 2008 Report Share Posted January 26, 2008 My Boss just passed his 33 bhp bike test ans baught a Cagiva mito...... How can i de restrict it for him ? It's already had the Exhaust done, are there any more ? It only pulls to 90mph at the moment....Wich is pretty slow for one of them !Any help would be great ! Jarrod Quote Link to comment Share on other sites More sharing options...
TomR Posted January 26, 2008 Report Share Posted January 26, 2008 Why has your boss bought such a puny bike?And restriction is different on a lot of bikes, from engine management to narrow intakes. Best off finding a cagiva forum. Quote Link to comment Share on other sites More sharing options...
Muel Posted January 26, 2008 Report Share Posted January 26, 2008 The most common things are.The washer in the exaust pipe.The main jet could be smaller to restrict fuel flow.I don't know what Cagivas are like, but I would imagine that this is all you need to do.Why didn't he get a real bike though? Quote Link to comment Share on other sites More sharing options...
Pashley26 Posted January 26, 2008 Author Report Share Posted January 26, 2008 (edited) Why has your boss bought such a puny bike?Why didn't he get a real bike though?Obviously not aware of how the bike tests work.......He's restricted to 125cc until he can do his Full bike test, And Cagiva mito's are fast as you like.....I've done the Exhaust, just trying to find out if there is an Inlet restriction too before i take the engine apart ? Jarrod Edited January 26, 2008 by Pashley26 Quote Link to comment Share on other sites More sharing options...
Danny Swindlehurst Posted January 26, 2008 Report Share Posted January 26, 2008 If it's the 6 speed Evo2 (99+ model)will need the chamber hacking off the side of the exhaust and a plate welding over it Some say you need to change the snorkels on the airbox lid to bigger ones and then up the jetting from 100 or 110 to 120 for the main, and from 55 to 65 on the idle jetsYou also get different sprocket's in the kit but they aren't needed, and I found 13:38 to be the best setup for when you come to replace them.If it's an older 7 speed bike then it should just be the exhaust that needs doing.hope that helps Danny Quote Link to comment Share on other sites More sharing options...
TomR Posted January 26, 2008 Report Share Posted January 26, 2008 Obviously not aware of how the bike tests work.......He's restricted to 125cc until he can do his Full bike test, And Cagiva mito's are fast as you like.....Ah, didnt realise he hadnt done his full test. Why not just do the full test assuming hes over 21? Quote Link to comment Share on other sites More sharing options...
Pashley26 Posted January 26, 2008 Author Report Share Posted January 26, 2008 (edited) If it's the 6 speed Evo2 (99+ model)will need the chamber hacking off the side of the exhaust and a plate welding over it Some say you need to change the snorkels on the airbox lid to bigger ones and then up the jetting from 100 or 110 to 120 for the main, and from 55 to 65 on the idle jetsYou also get different sprocket's in the kit but they aren't needed, and I found 13:38 to be the best setup for when you come to replace them.If it's an older 7 speed bike then it should just be the exhaust that needs doing.hope that helps Danny Thanks mate It's the 6 speed one, Ordered up the Jets and did the Exhaust today Think we might have been looking on the same website ?Ah, didnt realise he hadnt done his full test. Why not just do the full test assuming hes over 21?Without going to London (a bit of a trek !) he can't book a Full test for another 3 months because it HAS to be on a Saturday Thanks guys ! Jarrod Edited January 26, 2008 by Pashley26 Quote Link to comment Share on other sites More sharing options...
Spikenipple Posted January 26, 2008 Report Share Posted January 26, 2008 If he's not passed his full test, it's 14.6bhp he's restricted to, not 33bhp. Quote Link to comment Share on other sites More sharing options...
Pashley26 Posted January 26, 2008 Author Report Share Posted January 26, 2008 If he's not passed his full test, it's 14.6bhp he's restricted to, not 33bhp.Well, either way he can't much bigger than a 125...Jarrod Quote Link to comment Share on other sites More sharing options...
Joe Sheehan! Posted January 26, 2008 Report Share Posted January 26, 2008 If its anything like the RS125, you will need a Powervalve blade (sits near the exhaust port), Powervalve Solenoid (controls the blade) and a derestricted CDI. after that you will need exhausts etc, go on www.125ccsportsbikes.co.uk and have a look, theres a stickied thread in the Mito section about derestriction. Quote Link to comment Share on other sites More sharing options...
Pashley26 Posted January 26, 2008 Author Report Share Posted January 26, 2008 Cool ! Everything apart from the Reed Valve's been done.I saw one on Ebay earlier but i didn't realise what it was ! I took the tube off the exhaust and welded a plate over it, it's already got an Arrow expansion pipe and can on it. I've ordered - New Jets and a power chamber (holds excess fuel then injects it at ridiculous speeds) and a set of Iridium plugs.I took it round the block after i did the exhaust and it's bloody fast ! Jarrod Quote Link to comment Share on other sites More sharing options...
Ben Cox Posted January 26, 2008 Report Share Posted January 26, 2008 not bad, so hes past his test, got this bike and now its illegal for him to ride it due to modifications pushing power over the limit! Quote Link to comment Share on other sites More sharing options...
Pashley26 Posted January 26, 2008 Author Report Share Posted January 26, 2008 (edited) not bad, so hes past his test, got this bike and now its illegal for him to ride it due to modifications pushing power over the limit![Edit] Meh', can't be bothered for an argument. [Edit]Jarrod Edited January 26, 2008 by Pashley26 Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted January 28, 2008 Report Share Posted January 28, 2008 My mates cagiva would do 130mph....fully modded withall kinds of crud bolted to it....but my god that thing flew! Quote Link to comment Share on other sites More sharing options...
Wilson. Posted January 28, 2008 Report Share Posted January 28, 2008 My mates cagiva would do 120mph....fully modded withall kinds of crud bolted to it....but my god that thing flew! Quote Link to comment Share on other sites More sharing options...
Pashley26 Posted January 28, 2008 Author Report Share Posted January 28, 2008 It's true....I clocked this my boss's one in the E-Type at 120mph now it's de restricted....Bloody scary though ! Jarrod Quote Link to comment Share on other sites More sharing options...
