rsmith Posted January 25, 2008 Report Share Posted January 25, 2008 Hi all.I am new to trials and are in the process of building a bike. I've just bought a pair of Magura rim brakes, (retro yellow).I know it's too late to change my mind now but I was just wondering why you guys prefer these brakes to a pair of the many disk brakes available. I can't get a real answer from any of my mates.Also why is it that some prefer to run a disk on the front?Any info would be useful.Thanks, Rob Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted January 25, 2008 Report Share Posted January 25, 2008 Basically disc up front is preferred because it offers all weather stopping, with high power and modulation. A magura up front normally cannot rival this power without being grabby a(and usually savagely noisy ). With hard pads and smooth rim, the magura will give th same amount of modulation but offer less power.Most trials ridders still run a maggie on the back due to the positive on / off feel some say that disc simply cannot achieve. I personally run maguras front ( on a smooth rim )and back ( with a grind ) as i like the modulation on the front, and dont really need the extra power. Im running a set of racelines, and love them. most people will agree that hs33s from this era are far better than the 05 onwards due to a far better TPA (Turbo pad adjuster ) design and sturdier bar clamp.For a list of good pads, check the pads revioew section in Trials chat. Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 25, 2008 Report Share Posted January 25, 2008 Basically disc up front is preferred because it offers all weather stopping, with high power and modulation. A magura up front normally cannot rival this power without being grabby a(and usually savagely noisy ). With hard pads and smooth rim, the magura will give th same amount of modulation but offer less power.Most trials ridders still run a maggie on the back due to the positive on / off feel some say that disc simply cannot achieve. I personally run maguras front ( on a smooth rim )and back ( with a grind ) as i like the modulation on the front, and dont really need the extra power. Im running a set of racelines, and love them. most people will agree that hs33s from this era are far better than the 05 onwards due to a far better TPA (Turbo pad adjuster ) design and sturdier bar clamp.For a list of good pads, check the pads revioew section in Trials chat.the TPA is better, but only because its in a place that's less likely to get broken off. Watch out for it, because mine crossthreaded and i can't use it any more. People use hs33s at the back because modulation isn't as necessary on the back, but a brake that's reliable is. Rim brakes stop the rim, whereas disc brakes stopo the disc, but a disc is only designed to be stopped in a forwards rotation, and not backwards such as in a backhop. This means there's a small chance the disc could rip off. Quote Link to comment Share on other sites More sharing options...
sam ere luvin :Ptrials:P Posted January 25, 2008 Report Share Posted January 25, 2008 hi there, from were i live i have to go down a really big hill to get to the nearest decent riding spot, this is were front disk comes in use. but then again front magura if set up right is a guarantied lock brake which is useful for a lot of things so i would double magura. also if you are right foot forward and you run double disc there is a lot to small up and bend in a messed up side hop. hope this helps Sam x Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 25, 2008 Report Share Posted January 25, 2008 Personally i think the 04 magura's are better than 05's even if the tpa breaks you can replace it with a bolt the 05 ones you have to buy a new tpa lol and the lever on the 04 feels nicer Quote Link to comment Share on other sites More sharing options...
CRANK BRO Posted January 25, 2008 Report Share Posted January 25, 2008 hi guys new here myself was just about to buy a set of Magura Hs33 Brakes,when i noticed your post,im a bit lost when you say you use a grind on the back,what does this mean please?sorry im new.what are these brakes like to set up please? Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 25, 2008 Report Share Posted January 25, 2008 hi guys new here myself was just about to buy a set of Magura Hs33 Brakes,when i noticed your post,im a bit lost when you say you use a grind on the back,what does this mean please?sorry im new.what are these brakes like to set up please?It means you run a angle grinder round the rim to take paint off and leave a ruff endge for the pads to grip to....There are certain pads for medium harsh and light grinds some pads are a soft compound so if you run them on a harsh grind they wont last long! Quote Link to comment Share on other sites More sharing options...
Muel Posted January 25, 2008 Report Share Posted January 25, 2008 http://www.trials-forum.co.uk/forum/index....=100632&hl=That should tell you all about how to grind.You Grind your rim to put deep cuts in to the braking surface, so the pads have more purchase on the surface, which makes your brake work much better and produces that horrid noise everyone else loves. Quote Link to comment Share on other sites More sharing options...
CRANK BRO Posted January 25, 2008 Report Share Posted January 25, 2008 ok thats cleared that up for me,bu the way r smith,were abouts are you in the west mids please mate? Quote Link to comment Share on other sites More sharing options...
Troy Posted January 26, 2008 Report Share Posted January 26, 2008 Personally i think the 04 magura's are better than 05's even if the tpa breaks you can replace it with a bolt the 05 ones you have to buy a new tpa lol and the lever on the 04 feels nicer i like the 04magura too. i am now use a echo rim brake since the second 04magura was broken one month ago. Quote Link to comment Share on other sites More sharing options...
vinny.p Posted January 26, 2008 Report Share Posted January 26, 2008 Hi all.I am new to trials and are in the process of building a bike. I've just bought a pair of Magura rim brakes, (retro yellow).I know it's too late to change my mind now but I was just wondering why you guys prefer these brakes to a pair of the many disk brakes available. I can't get a real answer from any of my mates.Also why is it that some prefer to run a disk on the front?Any info would be useful.Thanks, RobI wonder if he realizes hes a full member. Quote Link to comment Share on other sites More sharing options...
