Revolver Posted January 24, 2008 Report Share Posted January 24, 2008 HelloIf more air gets into the brake, how long should I leave it before it'll get to the top? And do I need to pump the lever at all? Quote Link to comment Share on other sites More sharing options...
psycholist Posted January 24, 2008 Report Share Posted January 24, 2008 (edited) If it's a closed system like a Magura rim brake then you'll have to bleed it to get the brake working properly - it doesn't matter where the air is as all the fluid in the brake must be pressurised for the brake to work. If it's an open system like current Hopes (And pretty much every other hydraulic disk except the old C2's from Hope and Giant's own brand disks), then pumping the lever (Provided the lever is the highest point in the brake) can move air bubbles from the caliper/brake line to the reservoir where, if the bubble is small, they won't affect braking. If you pull the lever and let go of it suddenly that seems to help move the air quicker. Handy if you've shortened the brake line, swapped brake lever around or are topping up the reservoir after it has lost fluid through a loose fitting or brake pad wear has drained the reservoir.If you are shortening the brake line take the wheel out and pump the brake pads out before opening the brake up. Then after cutting the brake line down you can reassemble the brake and lever the pads apart to push any air bubble formed in the brake line back into the reservoir. Edited January 24, 2008 by psycholist Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 24, 2008 Author Report Share Posted January 24, 2008 I'm bleeding a hs33, but i've put a juicy 3 lever on it. It works, but i put air in when I put the fluid in >( like a twat Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 24, 2008 Report Share Posted January 24, 2008 I'm bleeding a hs33, but i've put a juicy 3 lever on it. It works, but i put air in when I put the fluid in >( like a twatCant you bleed it under water? with a water bleeed Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 24, 2008 Author Report Share Posted January 24, 2008 I shoud water bleed it really, but i've put the fluid in and I don't wanna like waste it. Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 24, 2008 Report Share Posted January 24, 2008 I shoud water bleed it really, but i've put the fluid in and I don't wanna like waste it.you wouldnt of used alot of fluid water bleeds the way to go but im not to sure if the avids have metal internals. Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 24, 2008 Author Report Share Posted January 24, 2008 i've decided i'll water bleed it. How do i go about converting from oil to water? Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 24, 2008 Report Share Posted January 24, 2008 Just undo the bleed bolts and pull the lever and fluid will come out .....i would take the lever and calliipers of the cable and blow them though with a pump and abit of water in the lever Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 24, 2008 Author Report Share Posted January 24, 2008 if i want to switch to water bleed, should i empty the system first? Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 24, 2008 Report Share Posted January 24, 2008 if i want to switch to water bleed, should i empty the system first?yes but if you are bleeding in a sink i would empty the system Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 24, 2008 Author Report Share Posted January 24, 2008 RIght. I'm going to empty the brakes of fluid, (put it in a pot for safekeeping) and then i'm going to footpump the slave cylinders so they're clean inside, then i'll try a bath bleedwish me luck Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 24, 2008 Report Share Posted January 24, 2008 RIght. I'm going to empty the brakes of fluid, (put it in a pot for safekeeping) and then i'm going to footpump the slave cylinders so they're clean inside, then i'll try a bath bleedwish me luck Good Luck Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 24, 2008 Author Report Share Posted January 24, 2008 first try, put my hs33 lever back on, replaced the main hose, water bled it using the bath method, and no response from the brake cyninders Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 24, 2008 Report Share Posted January 24, 2008 Hmm are you bleeding it writee? Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 24, 2008 Author Report Share Posted January 24, 2008 uts working nowwhat i'mdoing is covering the slave hole, pushing the lever in, covering the lever hole and releasing the slave hole, releasing the lever, and repeatingthat way it suchs water through the slave hole and pushes air out through the lever hole sick, it works thanks mod mike Quote Link to comment Share on other sites More sharing options...
Ladd Posted January 24, 2008 Report Share Posted January 24, 2008 uts working nowwhat i'mdoing is covering the slave hole, pushing the lever in, covering the lever hole and releasing the slave hole, releasing the lever, and repeatingthat way it suchs water through the slave hole and pushes air out through the lever hole sick, it works thanks mod mikeAnytime mate just ask Quote Link to comment Share on other sites More sharing options...
