danhalson Posted January 23, 2008 Report Share Posted January 23, 2008 hi can anybody help me please my snail cams keep moving wen i tighten my wheel up i go 2 jump and then my wheel moves wen i land dunno why thou this is my first time off using snail cams can anybody please help Quote Link to comment Share on other sites More sharing options...
Maximus Posted January 23, 2008 Report Share Posted January 23, 2008 hi can anybody help me please my snail cams keep moving wen i tighten my wheel up i go 2 jump and then my wheel moves wen i land dunno why thou this is my first time off using snail cams can anybody please helpHi,Place/turn your cams over so when you tighten you your blots, the snail cams should be rotating with them not against, pulling the wheel back, this makes it easier to set up, and they should be less inclined to move, rotate away from the conflicting force. Ok so the cams should be the opposite way round each side as the bolts rotate different ways. If you’re really having problems could try a spring loaded washer. Do you get me if not, ill take some pictures to explain? Quote Link to comment Share on other sites More sharing options...
danhalson Posted January 23, 2008 Author Report Share Posted January 23, 2008 Hi,Place/turn your cams over so when you tighten you your blots, the snail cams should be rotating with them not against, pulling the wheel back, this makes it easier to set up, and they should be less inclined to move, rotate away from the conflicting force. Ok so the cams should be the opposite way round each side as the bolts rotate different ways. If you’re really having problems could try a spring loaded washer. Do you get me if not, ill take some pictures to explain?well i sort of but not realy it would be realy helpfull if you could send some pictures mate Quote Link to comment Share on other sites More sharing options...
Maximus Posted January 23, 2008 Report Share Posted January 23, 2008 well i sort of but not realy it would be realy helpfull if you could send some pictures mateYep but yul have to wait till tomaro, ive got no lights im my shed. Basically, make sure the cam spins the same way as the nut, when the cam is moving the bike wheel back, try it. TRY IT <<<<<<<<<<<<maximus! Quote Link to comment Share on other sites More sharing options...
max-t Posted January 23, 2008 Report Share Posted January 23, 2008 What snail cams do you have? What back hub?The smooth ones tend to slip loads. It would probably be a good idea to invest in some 'notched' ones. Like these. Quote Link to comment Share on other sites More sharing options...
Muel Posted January 23, 2008 Report Share Posted January 23, 2008 Just make sure they are lamped up, I have only ever had notched ones and they have never slipped, but my mates smooth echo ones were shite, they just slipped all the time. Quote Link to comment Share on other sites More sharing options...
